View Poll Results: What would you go for?
Finished unit for $50ea (2 needed) 10 58.82%
Kit for $25ea (2 needed) 6 35.29%
Other (reply in comment with specifics) 1 5.88%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 03-11-2013   #81
scottfab
scottfab's Avatar
Default Re: Under Hood Lighting
Originally Posted by tf95ZR1 View Post
Hey Phillip,
Oops, I just saw that you changed the
lighting on/off switch/harness. Can't imagine
how that would change things.
Maybe dumb question, but can you
rotate the LED 180 deg?
I'll interject here that the LED unit I made was designed
to only go in one way. The thinking was to make it more
straight forward to install. Had I known some of these aftermarket
harnesses swap polarity I could have made the unit such that
it could be rotated.
Oh well.
Scott
Old 03-11-2013   #82
PhillipsLT5
PhillipsLT5's Avatar
Scott, thank you for all you have done & your continued concern!
Harness looks like mine, let me see if I can find the receipt & or instruction sheet to confirm
Right now I am running 1 old bulb & 1 new LED
Old 03-11-2013   #83
PhillipsLT5
Scott, after a trip down memory lane thru the receipts, that is the one I have 601-721, Mid America
Can you help?
Old 03-11-2013   #84
1991ZR1
I think my switch harness came from Mid America also. It's very easy to correct the polarity. You need to get the weather pack terminal removal tool. Just switch the terminals at the connector that gets connected to the light that is not working. The change should be made on the after market switch harness and not the stock plug. Either way will work but this way, if someone removes the after market switch, the light will still work.
Don't forget to turn off the switch or disconnect the battery before working on this. Otherwise those terminals are live.
The tool is just a tube with a handle to pinch the terminal locking tabs so you can pull the wire and terminal out. The tool doesn't cost much and you should have one anyway so you can replace those old broken weather pack terminal housings.
1991ZR1 is offline   Reply With Quote
Old 03-12-2013   #85
Looks fairly simple. Is this the process you went through and the correct tool?
http://www.youtube.com/watch?v=eNO49GYv5Ng
Old 03-12-2013   #86
scottfab
scottfab's Avatar
This is what I recommend. And the reasons it's best are also listed.
Scott
Old 03-12-2013   #87
1991ZR1
Yes that is the tool and process. It's much faster and easier to do than explain.
The tool and weather pack housings if needed are available at NAPA and probably most auto parts stores.
Old 03-12-2013   #88
Thanks just ordered a 3 piece tool kit on Amazon.
Old 03-12-2013   #89
PhillipsLT5
GC, send me the amazon link please
Old 03-12-2013   #90
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I had some amazon credit to spend lol
