#81 | |
![]() Join Date: Nov 2007
Last year I ran a 12.6 at 117, but my 7200 rev limit cut me off well before the trap. The oil pressure switch ended that day's further experimenting. This year I ran 13.0 at 115 on 7 cylinders, while laying down a thick vapor trail behind me. Naaa. The coolant injection experiment was not a good idea. P. |
#82 |
![]() Join Date: Mar 2007
It was reported after your run that mosquito counts were down
#83 |
Lee,
That's why Bob G was able to run as fast as he did. Fewer insects hitting windshield and slowing car down. BTW, in terms of overlaying Paul's dyno on mine, Marc H will be getting the data file from Paul's session so we can get an accurate compare of the curves and area under the curve. Looking at Paul's sheet, the increments on the two graphs are different. |
#84 | |
#85 |
Some more info to take a look at. Speed Inc. was good enough to send me the data files of Friday's runs. There's a compare of the first run on Friday with no additional tuning and the swap in of the SW Xpipe and last run of previous set with MFlow resonator in place. Numbers are very close but look at the AFR. Significant difference. Xpipe appears to have leaned the AFR by almost .5:1 requiring richening of the fueling. There's also a compare of the first run with the final run on Friday and then one of just the final run. If you play with the WinPep7 reader software, you'll find that torque increased in some spots by ~20lbft rw between the first and last run. There's almost a consistent 15rwtq/rwhp between these runs and removing the smoothing shows a Max HP of nearly 430rwhp which I expected.
#86 |
nice detailed write up of the differences . will show alot of people that they need to retune the car when going to an x pipe from a resonator shows the importance of retuning the car when you make a change before bitching that it doesnt run any faster . how many times have we done/heard that .lol
#87 | |
Now a nice 4.30 gear for the rear, and you can bench race with the best of 'em! ![]() (U know I'm juss pullin yer tail, buddy! LOL!) P. |
#88 | |
Absolutely. And its not the kind of thing where you buy a tune "off the shelf" either. I spent 2 1/2 hrs on the dyno Friday and so far almost 5 hrs total. And that's just WOT. I've probably burned about 50 cals for this motor so far. Some of the changes are minimal or tweaks. Some more substantial and involving quite a few parameters for driveability, idle quality, and PThrottle. ![]() ![]() |
#89 |
Very nice day in Chicagoland for mid-November. Had to take car out for a brief playtime. The power is intoxicating. 2nd and 3rd gears pull. You can feel the power on reserve. Just tip the throttle and there's MORE, period.
Torque? Yep! Banging 3nd gear, the car jumps as tires grab. Still keeping ASR ON with street tires but the Nitto Invos feel pretty good. I find myself looking for unsuspecting GTs, Sti's or M3s. Damn this is fun!!!!! What's fun is having a ZR-1 with 100k+ on the ODO and not giving a shi* about driving it to keep the miles down. |
#90 |
![]() Join Date: Feb 2010
Nice job Dom, sounds like all the effort paid off. I'm salivating, reading these threads. It's great having you guys doing all the beta testing, paving the way for us ZR-1 rookies. I need to start ordering parts!
