Old 04-01-2011   #81
Polo-1
Default Re: Some "Dynomite" Heads!
if you look in the port of GVD vs Rob's you will see it.
It's the old knife edge or flat edge debate.
Old 04-01-2011   #82
Yes, I noticed that in my heads. Port divider has a flat edge to it.
Old 04-02-2011   #83
Locobob
After tiptoeing around the valve seats working the chambers I finally got smart and had my local machine shop cut me some junk valves to use for protecting the seats. I think they came from a Toyota or something but anyhow I had them cut so that they fit almost perfectly flush with the chamber roof. Wish I had done this earlier - makes the job so much easier.
Here are some pics of the chamber work coming along.
Robert
Old 04-02-2011   #84
Polo-1
you might be on to something Rob " under sized valves "
Old 04-07-2011   #85
Locobob
Almost done, just some fine tuning to do.
Robert
Old 04-07-2011   #86
Polo-1
a little more polish and they will be ready to hang on the wall
They look really nice Rob.
Old 04-07-2011   #87
I have to stop looking at your work Bob or I will start to hate my stock ZR-1.....which I used to be extremely happy with I might add!
Man that is just some fine head work! I have head envy!
Old 04-07-2011   #88
Stock is boring Tom. Take a ride to Chicago
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 04-09-2011   #89
Locobob
Headers, exhaust and porting really wake up the motor and let the 32 valve design shine.
Robert
Old 04-09-2011   #90
Locobob
CC ing again. I did this before starting just to establish a baseline but now the focus is on chamber to chamber consistency. Anyhow the my results after working the chambers came in at a smallest of 41.5cc and a largest of 42.5cc. I do each chamber twice as an error check, if I see any substantial difference then I do it over until I get a consistent result. My method has proven to be accurate and repeatable, I figure my margin of error is probably under .5cc. The largest volume was the chamber I used to make my template - which I expected as it shows the difference between the template and the marker trace on the others. The next step is to remove some more material to bring all the chambers up to the volume of the largest.
Here we have a chamber filled with water and a bit of food coloring. The plate over the top is 1/2in plexi with some Vaseline around the edges and valves for sealant.
How much difference is 1cc? About 2.4%
Here is 1cc poured into the corner of a chamber - probably looks like more than it is since the head is tilted. Anyhow when I'm done they will all be at 42.5cc and then the heads will be surfaced to achieve the desired compression ratio.
Robert
