11-30-2009 | #71 |
Re: 1st LT5 engine pull, looking for tips and tricks
Jeff, Tom and Jerry,
Thanks for the comments and inspiration........it will surely keep me going. I have to try to do a little during the weeknights or this will take me forever. I really want to drive this Z again. Aloha, |
11-30-2009 | #72 |
Reminds me of when I was painting an SS396 El Camino. Got to looking at the engine bay and how dirty it was and how it would look like crap if I didn't do something with it. Next thing I know the front end is off and the engines out. No other way to make it right.
Looking great Craig.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
11-30-2009 | #73 | |
02-08-2010 | #74 |
After cleaning the block several times and then with marine clean and metal prep, taped up to prepare to paint the block with POR-15 Stirling Silver. Finally ready for the installation of the liners!! |
02-08-2010 | #75 |
Now that's going to be a very sweeeeeet looking motor when it's dunn!
It is soooooo clean....looks like the day it was born!
02-08-2010 | #76 |
Thanks guys, definitely not stock or NCRS ever again, but it feels good and as long as it runs as good it looks I will be happy. I'll be sure to start a new thread with the assembly.
02-10-2010 | #77 |
Hi Craig, Where was the cam timing and what did you find to explain your low compression? Good luck with the rest of the project. George
02-10-2010 | #78 | |
Unfortunately I don't know exactly how far off the timing was other than the pins when checking with factory setting method. I could not figure out the true cause of the low compression other than the fact that the entire driver's side bank was lower and to me related to the camshaft timing. Testing with vacuum and engine running did not give any specific indicators and appeared normal using Mightyvac procedures. Did not do a leak down test and was going to rebuild anyway at the time. I had decided to just get the heads reworked and replace the bottom half components so I could cover all basis and shoot for more HP at the same time with all the porting work. I will definitely degree the camshafts upon assembly or at a minimum verify all the settings to ensure within specs. Thanks for your wishes and I will need it. Just waiting on some piston rings since the bottom half assembly I bought arrived with all but one of the oil rings broken or damaged. |
02-10-2010 | #79 | |
Thanks for your thought and tips. I'll take everything into consideration when reassembling. |
02-10-2010 | #80 | |
Hope everthing goes well and keep us updated. David |
