Old 12-04-2020   #71
Thomas ZR-1
Thomas ZR-1's Avatar
Default Re: Revision Corvette ZR-1 model year 1990 #125
Therefore the cam lobes maximum lift was timed to: intake 114? after TDC, exhaust 110? bevor TDC.
Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 12-04-2020   #72
Thomas ZR-1
Now the valve covers, the engine front cover, the new water pump, the oil filter adapter with new sensors and the injector housings could be fitted.
Old 12-04-2020   #73
Thomas ZR-1
At the beginning I told you that the car and the engine would be rebuild in absolutely OEM condition. But the intake system consisting of the injector housings and the plenum could not stay original. The design of the intake ducts is really unfavorably for the flow (especially the area where the fuel injectors ends in the ducts). Partially nearly 50% of the sectional area is covered. This throttles at higher RPM, the engines cylinder charging could be better. So much engine power gets lost. So I did my standard porting for the LT5. All reductions were removed and the channel diameters got enlarged a little bit.
Old 12-04-2020   #74
Thomas ZR-1
The belt drive could be completed with a new alternator, AC compressor, steering pump and overhauled belt tensioner.
Old 12-04-2020   #75
Thomas ZR-1
The fuel rail was assembled with new stainless steel injectors (ACCEL 150821).
Old 12-04-2020   #76
Thomas ZR-1
The plenum was completed with the throttle body and the air horn.
Old 12-04-2020   #77
Thomas ZR-1
Rebuild finished: assembled LT5 on the engine stand.
Old 12-04-2020   #78
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Incredibly beautiful work!!!
The restoration of ZR-1's will continue to pick up speed.
The lines are blurring between the cost of a no/low mile original and the cost to return a used one back to as built day one quality.
Others have done it here, and this is just another example and a superb one at that.
Congratulations!
Very well done!
Marty
Old 12-06-2020   #79
tgonyaw
Very nice!
Top notch treatment for a top notch car!
tgonyaw is offline   Reply With Quote
Old 12-06-2020   #80
I have a new GM part, not sure what it's called maybe the baffle that goes under the radiator your welcome to it free,you pay shipping. This offer is only for this project. I bought this for an 84 years ago it should be the same for 90.
