08-31-2008 | #71 |
Re: Fuel Injectors
If any of you need O-rings - I have them - $1.50 / O-ring. I did a lot of research - They are Vitone rubber and are resistant to all of the bad things that make them go bad and have a fantastic temp. range. I learned my lesson when I tried to by them from GM and Kurt white - Kurt wanted $16.00 per oring and my local GM dealer wanted $20.00 - He was only able to find -(1). So I went looking on my own - did not want to let KW take unfair advantage of me. So if you are interested let me know - They are easy to drop in the US. MAil - You will need a Qty of 8.
Just PM or send me an e- mail Karterdon@aol.com Don Yoakem 91-#267 Dark Red Met. |
09-01-2008 | #72 | |
Re: Fuel Injectors
09-04-2008 | #73 |
Re: Fuel Injectors
I have read all eight pages of the fuel injector topic and did not see the answers to my questions:
1) What are the ratings for a '94...21#?, 22#?, 24#???? 2) Are the primary and secondary ratings the the same? 3) If I go with the Accel's...mentioned in the posts...would I need the O-rings mentioned in the post? Thanks
Clint aka billybaloneey '94 - C4 ZR-1 #445 - Black/Black '05 - C6 silver/black 6sp '85 - C4 white/graphite (almost done) automatic '78 - C3 silver/black (a work in progress) automatic |
09-04-2008 | #74 | |||
Re: Fuel Injectors
09-05-2008 | #75 |
Re: Fuel Injectors
I visited one of the suggested sources for fuel injectors...Atlantic Speed.com and the only LT5/ZR-1 injectors they list are 21#'s. They show the 19#'s for use on '93-97 LT-1's.
Are there any advantages or disadvantages using a 21# (Accel) instead of the recommended 19#'er?
09-05-2008 | #76 | |
Re: Fuel Injectors
I ordered sixteen of the #21's from Atlantic Speed for my 94 Z. |
09-05-2008 | #77 | |
Re: Fuel Injectors
09-05-2008 | #78 | |
Re: Fuel Injectors
09-05-2008 | #79 | |
Re: Fuel Injectors
Order Accel 150821 cut off the alignment tab and remove the lower o-ring on the injecotr body for the primaries and install. |
09-05-2008 | #80 | |
Re: Fuel Injectors
Plan to put them in this winter along with the P&P plenum and IHs. |
