#71 | |
![]() Join Date: May 2010
Hey Yun, Thanks so much for always sharing your how tos and saving so much time and energy for others that follow. No, I have to do the fog light ground and will attack it tomorrow. Coincidently I need to install ETC reader for toll booths. It is hell to get in and out of the car and dangerous; especially from the opposite side. While I'm under the dash, might as well attack it. The bumper is a BSM Yokohama. A friend helped me find a used one and boy did it need surgery. Happy New Year too!!! Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#72 | |
U have a link for those? |
#73 |
![]() Join Date: Aug 2006
Ed,
CREE LED you are referring to - are these LED bulbs only or 5x7 including reflectors? |
#74 |
Craig,
FYI - later cars have smaller relays that sit on a tray with a rectangular plastic cover. To remove the cover squeeze the narrower sides of the cover. This will cause the plastic prongs to retract and allow the cover to slide up. Took me awhile to figure this out... |
#75 | |
Thanks so much for another heads up tip. My first time going under dash on this 95. Any recommendation about key on ignition source to tap into on driver's side for electronic toll booth card reader? I have to install this sucker today. ![]() Like Hib mentioned I might want to pull the seat for more comfort under there. Might as well install the Corbeau seat while I'm at it.... ![]() Do you see how one thing leads to another? Lol! Sent from my iPhone using ZR-1 Net Registry
#76 |
![]() I hope it's not these CREEs? https://www.amazon.com/New-World-Mot.../dp/B0162YBFD8 Sent from my iPhone using ZR-1 Net Registry
#77 | |
#78 | |
#79 |
![]() Join Date: Aug 2012
It is so nice to be able to see at night, we have lots of deer out this time of year and things that go bump in the night scare me! After Yun did the install, I went to a MD inspection station and paid $28 for them to do the alignment. Both lights were low and to the left. With bright LED's you want to be sure they are in the right position.
Happy New Year to all my ZR-1 brothers....hope for a safe, healthy and successful 2017.
#80 |
Thanks again Yun. The tip for the yellow power window wire was spot on and it took no time at all to tap. Elephant memory my friend. Thanks Charlie, it better make sure my aim is good to go. Supposedly some to do with driving on the opposite side of the road here and same European standard lights instead of DOT.so I'm illegal here. JW Speaker sell LED ECE versions, but too expensive. Happy New Year!
