05-09-2014 | #71 | |
Re: Headers Installation...
Chuck next week will be impossible for a me. A young man still having to grind out to make a buck! I appreciate the offer and hope you have a great time. You and others should look into the show at MB in June I spoke of! |
05-09-2014 | #72 |
Headers and auto,
I use JEAL headers with power effects cat back system.When i put the 4l80E auto in i removed the ball joint on drivers side and made it a slip joint just like the pass side. On the pass side i cut the collector just after the weld a pie shape to move the collector away from the transmission pan by about 3/8 in. I installed the shift cable then the exhaust on drivers side of course it rubbed , marked the rub area removed exhaust made adjustment. Re install shift cable then exhaust and got just enough room. Ok now remove exhaust for room to work rapped DEI alu tape around shift cable about 6 in long. I left the shift arm uncovered. Now because the exhaust tubing hangs a little lower i routed the shift cable over the top of the transmission which helps keep the cable away from the exhaust pipe. I have some pics but having trouble posting them. i can e-mail to you if you what them. Some exhaust tubing of the same size as the power effects was used to connect the collectors to the power effects curved pipe then to the resonator John |
05-09-2014 | #73 | |
Sounds like I'm having a picnic, compared to THAT! I WOULD like to see some snappics of that hardware...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 05-09-2014 at 02:59 PM. |
05-10-2014 | #74 |
Do cat shields go into place with headers here???
05-10-2014 | #75 |
I put back all the ones that fasten to the frame & tunnel, just not the ones that were on the original manifolds.
05-10-2014 | #76 |
Got it there Steve; thanks...
And the AIR pump? Just pull the plug?
05-10-2014 | #77 |
Yes, I also removed the air pump completely and covered the plugs so they would not get corded.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 05-10-2014 at 07:22 PM. |
05-11-2014 | #78 |
Still working on getting up photos. Here is the THERMO-WRAP that i used on the
shift cable. DEI cool -tape in Jegs on line catolog, part # DEI 186-010408 cool-tape 1 1/2" wide by 15 ft. long. Price just 17.99 . John |
05-11-2014 | #79 | |
I got headers both sides locked in, FORGOT TO GET THE DIPSTICK IN PLACE. Hope it will snake in between the pipes... P side O2 not connected yet either... Will it reach? Will I be able to re-route the harness when we get back on it? Rest of pipes should be a cakewalk - had to pack up and head for the NC coast for a week here.
05-11-2014 | #80 |
here are the photos of transmission and exhaust system .
