Old 11-21-2013   #71
BigJohn
BigJohn's Avatar
Default Re: wheel refinishing?
Originally Posted by nelson007 View Post
I saw a newer zr1 with black wheels and a red stripe.Is that factory or did some just paint the stripe?
Thanks,
Nelson 007
That would be 2012 ZR1 Centennial Edition!
Old 11-22-2013   #72
So I got my wheel back today.. Well worth having them done..
They are Powdercoated in color and then Powder Clear
Lifetime warranty from defects etc..
Asked the guy I worked with and the color is a close enough match you will not be able to tell.. I will get some pictures once I get them out of the box and bolted back tot he barrels.
Now for a hood....... and get the rockers done
Old 11-22-2013   #73
Before:
close up of original color
After:
Old 12-01-2013   #74
Now to decide what to do about bolts..
I have 40 of the one on the left, 120 of the one on the right
any thoughts?
Old 12-01-2013   #75
WVZR-1
any thoughts?
I would think there's a couple reasons why I might choose to do 40 to match the 120. 1. you need fewer 2. it's certainly the type most frequently seen with the larger diameter flange with most multi-piece wheels.
I would think it important to match the shoulder of the bolt also to the 120 also. I'd think the shoulder length is maybe just a couple mm short of the total depth of the bore for the multi-piece when assembled. You didn't mention size or a post a profile so what I mention could be speculation but I wouldn't think. The one on the right looks like it might carry a "trademark". Yes/No?
I would think it not a problem. The catch could be is that I believe some of the multi-piece are done with 7mm hardware. Yours are?
Wheel centers certainly do look good. They did you well.
Old 12-01-2013   #76
I will get length and info later.. they are 8mm head not sure if actual thread size
Old 12-01-2013   #77
Z06scentair
Z06scentair's Avatar
They look awesome!
Z06scentair is offline   Reply With Quote
Old 12-01-2013   #78
USAZR1
USAZR1's Avatar
Those turned out really nice,Jeff.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
Old 12-02-2013   #79
bolt on Right says "R O" and "TITAN"
both are M6 as far as I can tell, one is about 28-29mm the other 32mm
Found some chrome plated ones on eBay for $60 per wheel r $220 for all 4. I doubt I can get these parts from Speedline, not sure where else to look
Old 12-02-2013   #80
Blue Flame Restorations
Jeff, have you considered a stainless fastener? I so often see chrome hardware rusting just from tightening the fastener to the wheel.
Just a thought.....
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
