View Poll Results: What would you go for? | |||
Finished unit for $50ea (2 needed) |
10 | 58.82% |
Kit for $25ea (2 needed) |
6 | 35.29% |
Other (reply in comment with specifics) |
1 | 5.88% |
Multiple Choice Poll. Voters: 17. You may not vote on this poll |
#71 |
Done.
#72 |
![]() Join Date: Sep 2005
I received the lights today and found out something that people with aftermarket wire harness with switch for the under hood light need to be aware of.
I installed the LED light on the passenger side and it did not work. I removed the LED and tried the other LED on the passenger side with the same result. The stock bulb works. I installed the LED on the driver side and it worked. I changed to the other LED and it worked also. Next, I checked the voltage at both light housings and found that the passenger side was opposite polarity from the driver side. I tried plugging the passenger side light wiring into the stock wire harness and the light works. I will need to switch the terminals in the aftermarket terminal housing to make it work. I guess they didn't worry about polarity when they made the switch harness because it doesn't matter with regular bulbs. It could just as easily have been that both sides wouldn't work or only the driver side wouldn't work. Scott. It seems that the lense rests against the LED's. Is this ok or should I add a gasket to the lense to add clearance? |
#73 |
![]() Join Date: Sep 2012
Got mine yesterday. Thanks, Scott. This will be one of my first mods when I get my car back from Corey.
#74 | |||
![]() Join Date: Jan 2009
We're going to need more data from more LEDs assembly users. I took pains to make the assembly such that it could only be installed one way. That may have been a mistake if half of the lamp holders are wired the other way ![]() Quote:
Thanks for bringing the issues up.
#75 |
I think the aftermarket harness plugs into the stock harness on the driver side. The light housings for both sides plug into the aftermarket harness. The change in polarity occurred in the aftermarket harness. I don't think anyone with stock wiring will have any trouble.
#76 | |
![]() Join Date: May 2010
I have the Gordon Killebrew under hood lamp switch as sold by Gordon and Corvette Central. I can't imagine when I installed it years ago that it would cause a polarity issue, but I will let you know as soon as I receive my LED assembly. Thanks again, Craig ![]()
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#77 |
I got my lights today
I have the same problem as 1991 ZR1 Passenger side LED will not work, stock bulb does Driver side OK I do have a on/off switch/harness made by?, bought from catalog co.? A suggested fix to this? |
#78 |
I prob will be in the same boat. Phil.
#79 | |
I found a picture of this harness Can anyone confirm this is the product? http://www.mamotorworks.com/corvette...%20switch%20c4 If someone that has this unit and willing to call me I may be able to come up with the least painful option. PM me I do know the clips that hold the bulb are not swappable since one has the contact tab for the mercury switch.
#80 |
![]() ![]() Join Date: Aug 2005
Hey Phillip,
Oops, I just saw that you changed the lighting on/off switch/harness. Can't imagine how that would change things. ![]() Maybe dumb question, but can you rotate the LED 180 deg? Last edited by tf95ZR1; 03-11-2013 at 08:22 PM. Reason: Duh Wanted 2 |
