#71 |
Do LT5's have camshaft and/or crankshaft position sensors?
Also, where is the ignition module located? |
#72 |
How funny, just saw it. The auction says it fits an LT1, LT5, 3.1L Regal, Grand Prix, Lumina and Cutless........... LOL ! Could that actually be accurate ?
#73 | |
Crankshaft is located on passenger side of block. Ignition module is underneath the plenum. Neither 3 of these components go bad on a common basis. |
#74 | |
1. New Plugs and Wires 2. New Fuel Filter 3. Tested both fuel pumps...... tested OK 4. O2 sensor readings look ok 5. New Accel injectors and Fuel Pressure Regulator ECM ? Coils ? |
#75 |
![]() Join Date: Feb 2006
The L98 ECM crosses to about 10 other GM applications. The LT5 ECM is specific to the ZR-1. Check with your local parts store or junk yard.
#76 |
#77 |
#78 |
![]() Join Date: Dec 2003
I would try changing the spark plugs again.
It's cheap and easy. Just try the cheap AC-Delco 41-602 cost about $15 You never know if some parts guy droped them. I seen a guy throwing plugs on the counter from about 10ft away to see if he could land them on the counter like he was playing basketball ![]() Otherwise check Coils. Pete
#79 | |
#80 | |
Howdy, I was just curious if anything else has been learned since the last postings? I am very curious as I think I have basically a '91 with "carbon copy" symptoms of your problems also! ![]() I just started checking everything before a plenum pull, but I already have RC injectors and a fuel filter replaced. I guess I was hoping it was bad gas, but I know better since it ran good without any fill up in between. Anyway, just hoping it is not a ECM. ![]() Lee |
