06-06-2021 | #711 |
Re: TB removal and then some!!!
Great job! Highly appreciate that you shared your work!
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991 |
06-06-2021 | #712 | |
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
06-11-2021 | #713 |
Wow it took me two days to read this entire thread. Roadster you have a lot of Patience my friend. Loved all the details and great work. I wished you lived closer to me as I would have lend a hand just to learn what you are going through but I have learned a ton.
The thread title "TB removal and then some" THEN SOME no doubt!! Thanks again and I cant wait till you get that Black beast out on the road. |
06-12-2021 | #714 | |
btw....if you want to check out another thread I did on front fender well cover restoration...then click on the link for that info....yes we live on opposite sides of the State....too bad we are not closer as you mentioned.... https://www.zr1.net/forum/showthread.php?t=27471
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 06-12-2021 at 01:14 PM. |
06-12-2021 | #715 | |
I will definently read that post. Will you be at Carlisle in a few months? |
06-12-2021 | #716 | |
Sent from my SM-G981U using ZR-1 Net Registry mobile app
06-12-2021 | #717 |
Got back to work on the Z today... primarily cleaning on the RF suspension...as mentioned many times before....the amount of grease and grime accumulated over the years is something...but cleans up relatively easy...although time consuming getting into every nook and cranny is worth it in the end...
Also checking out the control arm bushings...there are some cracks in the uppers...they still should last for many years with the amount of planned miles for future years... plus don't know if I want to dig further into the suspension at this time...although this would be the perfect time to do it....[emoji848][emoji848] Pic #1...primarily cleaning...still more to do... Pic #2...amount of grease allover the lower ball joint.... Pic #3...that brace by the lower control arm was all covered with grease...notice the 2 spots of grease there compared to the cleaned part of the brace...nice to be clean... Pic #4...this is time consuming when in the garage....as you can't use a power washer to get done quicker...so you do what you can do... Pic #5...upper front control arm bushing...although cracks...should still last for a while... Pic #6...upper rear control arm bushings...cracks....but I have seen worse...still would be the right time to do the job...but do I want to get in that deep....[emoji848][emoji848]20210612_192659.jpg20210612_160741.jpg20210612_151610.jpg20210612_153018.jpg20210612_162626.jpg20210612_162616.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
06-15-2021 | #718 |
Don't know if anyone is interested....but C&S Corvette just updated their web site about a hour ago with the SuperPro bushing kit back in stock.... I decided to go for it and just made the purchase....looks like the Z will take just a little bit longer to get back together....but should be worth it for sure....
https://www.corvettepartscenter.com/...on-bushing-kit
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 06-15-2021 at 04:41 PM. |
06-15-2021 | #719 |
Tom,
When I redid my front suspension, lower control arm bushing replacement was easy. Upper, not so easy. At the time, corvette control offered re-bushed uppers and that is what I used. When I searched today, couldn?t find the same at corvette central but corvette mods website turned up below. Doesn?t say left or right or both. Might want to give them a call. https://www.corvettemods.com/C4-Corv...hoC6osQAvD_BwE |
06-15-2021 | #720 | |
As far as Corvette Mods go....I stay away from them....based on multiple members in my FB Corvette Groups....99% have had bad experiences with them and won't use them again... I keep getting deeper into the 94... someday I'll get it back together... Hope everything is well on your end...and that your 94 is running good....[emoji16][emoji16] Sent from my SM-G981U using ZR-1 Net Registry mobile app
