10-03-2005 | #61 |
Re: Group Purchase of a Samco Air Intake Duct
Great news guys.
You can order the hose kits as well, and although I don't know the cost yet, it will be much better than the price you have heard floating around at $370.00. I am even trying to work on a reduced price for those of you who want both the Air Duct, and the Hose Kits. I should have an update in two days as to all prices and color availability. I will then be taking final orders so keep checking the thread. |
10-03-2005 | #62 |
Location: I'm in a constant state of euphoria in the Z!
Noob question here, Which hose kit?
Life's too short to be unhappy! [IMG]http://i4.photobucket.com/albums/y128/koolaid117/Montage.gif[/IMG] |
10-03-2005 | #63 |
Im guessing radiator to and fro/throttle body coolant hose, etc...
if its a vacuum hose kit put me down for 30.
"Mr. President, we must not allowwww... a mine shaft gap!!" -General Buck Turgidson 1994 ZR1 - White on Black |
10-03-2005 | #64 | ||
Exactly, the coolant pipe, outlet lower, outlet upper, bypass hose, inlet rear. Many people have been asking for them as well. The price that I can get will be much lower than the $370.00 that is being offered in some circles. Quote:
10-04-2005 | #65 |
If coolant hoses are available, sign me up for a set of those in black as well as the air duct.
Thanks, =D> |
10-07-2005 | #66 |
Hi Z Factor, I would like to sign up for the complete cooling hose kit, black if possible but if not I'll take what ever we can get. I've heard that those samco type cooling hoses are worth it!
If it helps and/or is required I'll sign up for an intake hose, black. I don't need one because I made my own fake Copland Duct using a knock off I got from corvette central & some S/S duct. Like I said I really, really, really want the cooling hose kit. I will take the intake hose if it helps get the rest of the guys a better price. Thank you for doing this! Tom Also, thank you very much for the help on my injectors Q's!
10-07-2005 | #67 |
If it is not to late I will take one air intake duct also. Make mine a black one thank you.
1992 ZR1 #330 white/white |
10-08-2005 | #68 | |
It is not required to buy both, but when I place the order for the Air Ducts and Coolant Hoses, the more units we get will put us closer to a price point to lower the cost. I suspect it will look nice to have the duct matching the coolant hoses as well, but it is up to you. Let me know because I think we will place the order this week. |
10-09-2005 | #69 |
Count me in for a set of hoses and an air duct, please.
Thanks Bill |
10-09-2005 | #70 |
Hi Z Factor, Okay I'm in all the way! Put me down for both:
One (1) black air duct One (1) set of black, or whatever we get, coolant hoses. Ah, now for the rookie Q. My Z has the sprung steel clamps, do I re-use those on the new hoses? Is there a recommended Type of clamp to use with these hoses? I don't want to ruin these by using the wrong clamps. Thank you Z Factor! Tom
