#61 |
In my case, the tie wrap is there to put some of the tightness back into the hose fitting lost due 17year old rubber. It would slip off rather easily.
#62 | |
On to the alarm issue, I have never seen an alarm incorporated into a C4 that has been done properly with out screwing something else up, or having the install just be hacked in there. I despise aftermarket alarms in C4's. As far as the code 42, they probably tapped into the wire off the column, and caused the issue. Luckily they did not blow the bag. |
