10-25-2008 | #61 | |
Re: LT5 Assembly Project
Make note of the oil hole on the idler gear for reinstallation. The almost last thing after timing I put on was the timing cover to build up oil pressure to watch and verify oil flow to idler gear and watch tensioners to work right without binding since I had never reset one before until then or I probably couldn't of slept. Do you have the reset procedures for the tensioners? Marc Haibeck has some on his site and I've got some more that was posted a while back. Unless your getting new ones for 500 or so.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
10-25-2008 | #62 | |
Watch how the primary chain gear comes off the crank cause it's not murphy proof. 90 fmm shows it one way and the supplement fmm shows it the other way but I forget which one is right. Oil pump will have to come off it your splitting the block. It's not fun to realign unless maybe you have the tool. Not sure if it would help on tear down but hanging the engine upside down will make it easier to reinstall the chains so they don't bunch up.
10-25-2008 | #63 | |
10-25-2008 | #64 |
It's pretty much fool proof. You pull it apart, clean and compress and move the clip with a pick to retain.
10-26-2008 | #65 |
sounds like to me your doing good. one step at a time. keep it up. BTW, you have a way to measure piston to wall clearance, plus to see if you have any skirts collapsing, (the pistons your worried about)?
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
10-26-2008 | #66 |
+Before removing the lower crankcase (girdle) you will need to remove the cam chains, oil pump, rods/pistons. The cast iron you see is cast into the aluminum, lower crankcase.
Glad the bolts arrived "timely".
10-26-2008 | #67 |
Whats the story on replacement rings? What about Rod bolts, etc?
LGAFF 92 ZR1 #234 |
10-26-2008 | #68 |
rings are no problem. rod bolts...you want to change or you think you need to change?
10-26-2008 | #69 |
I thought rod bolts tended to stretch?
Who has the rings?? LGAFF 92 ZR1 #234 Last edited by LGAFF; 10-26-2008 at 02:49 AM. |
10-26-2008 | #70 |
Total Seal in AZ. can do anything...FAST. let me know if you need a contact? they turn around rings for me in two-three days...crazy. don't get carried away though ...make sure your pistons are o.k. first
