Old 03-22-2010   #61
Default Re: Coil Over Installation
I assume the upper brackets are what Carter is making?
Old 03-22-2010   #62
carter200
carter200's Avatar
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 03-30-2010   #63
any updates?
Old 03-30-2010   #64
Demps
Demps's Avatar
Work is killing me. Have the rears ready. Need a more agressive way to open the rear frame. This weekend.....maybe.
Old 03-30-2010   #65
Ah understand.. sneak peek of the custom carter pieces??
Old 03-30-2010   #66
Demps
Demps's Avatar
Old 03-30-2010   #67
he did just the top piece?
Cool deal.. now to find out what a set will cost
Old 03-30-2010   #68
Demps
Demps's Avatar
Well...had the bottom bolts done locally. The top pieces need a little refinement to be perfect. We'll get them right for everyone else. Need to get the install complete to finish the design.
Ted
Old 03-30-2010   #69
looking forward to the pictures
what did you do for the bottom bolts?
Old 04-06-2010   #70
Demps
Demps's Avatar
Boy, I've used every Sunday school word in the four-letter language. I have a recommendation, pay someone! I learned more lessons than I ever want to learn again.
Had the car back to together and it drove wonderfully. The more I looked at it, the more I wanted it lowered another inch. Went at it today. The process is quite involved: use a strap wrench to hold the lower collar while using the spaner wrench to adjust the mount height. Well the coil would turn ever so slightly. Heard what I think was the gear clip pop off. Have to take the rears off again to fix--and it is no small feat.
When finished I will write up all of my lessons learned and will provide my particular height adjustment for the fronts and rears.
Carter and I are collaborating on a near perfect adaptation of mounting hardware.
Ted
