Old 07-06-2008   #1
Polo-1
Default Parting out 1991 ZR-1
Here is a small list. Ask if you need something that not listed yet. Motor and Trans are gone.
1991 ZR-1 LT5 Parts List Car was Red/Red with 61 k on it
Rear view Mirror $25-Goldcylon
Engine oil cooler…$25 -63vettezo6
Engine oil cooler hose….$150-Goldcylon
Air Cleaner Assembly with K&N..$65-Chris
Complete Dana 44 Conversion Kit…..$1800
Front Left sideTurn #16514491….$15-Goldcylon
Front Right side Turn#16514492….$15-Goldcylon
Rear side marker right#16508520..$15-Goldcylon
Rear side marker left#16508519..$15-Goldcylon
Front Fog/Turn left….$45
Front Fog/Turn right…$45
Reverse lights pair ………$25
Horns…..$15
A/C blend door#10158085….$10
Blower Motor……$15
Blower housing under dash…$40
Blower housing #52450785 engine side….$200 both parts-63vettezo6
Left and Right Gills panels……$40-DMark
Hood Latches……$25-1991ZR1
Hood Latch cables..$25
Accelerator pedal…..$20
Accelerator/cruise cables…….$25
Emergency Brake handle ……..$25
FX3 shock controller rear set…..$60-Chris
FX3 shock controller front set…….$60-kabnvtt
Rear shock pair…….$75-63vettezo6
FX3 seat switches…..$30-Goldcylon
FX3 computer…….$50-1991ZR1
Front shock pair(New)…..$150-63vettezo6
Upper Rad shroud(with stickers)…$50-63vettezo6
Coolant over flow……$10-dbriana
Vacuum ball….$5
Fan Assembly………..$75-Chris
Lower Rad shroud…..$10
Wiper motor……$10-xlr8nflorida
Front impact bumper………..$40
Rear Impact bumper (ZR1)……$75-Chris maybe
Rear bumper (no light/moldings)….$500-63vettez06
Master Brake cyl…………..$50
Battery tray………..$10
Upper coolant reservoir…..$15-dbriana
Clutch/brake pedals…..$15-Gustav(brake)
Cruise control bracket…..$10
Air pump Smog stuff…….$25-xlr8nflorida
Left head light assembly (w/motor)..$50-1991ZR1
Right head light assembly (w/motor)..$50-1991ZR1
Driver side mirror…$45
Passenger side mirror…$45-jerrydirks
Gas tank…..$25-Chris
Evap canister&lines….$25
Borla 2.5 (mid pipes gone)….$200-Chris
ECM bracket (small crack)….$5
Spare Tire Bag(bad zipper)….$25
Spare tire…………$25
Glove box tray(dash)…$5
Glove box door(dash)…$10-dbriana
Head Light module….$40-1991ZR1
Inside wire harness (from dash/fuse boxes 2/relays/FX3/doors/seats/ABS/tail lamps) this was $1147 new from GM no longer…..$400
A/C dash vents………$5 ea.-dbriana (left side only)-xlr8nflorida the rest of dash vents
Rear tail lights w housings …..$30-xlr8nflorida
Instrument panel (Canadian)…..$350
Head light switch…….$25
DIC panel……….$20-xlr8nflorida
Bose/CD and module ( unknown cond.)….. $75-webruke
A pillar moldings……$5ea
Power key switch/and bezel ( switch and bezel are epoxy together it works)…..$25-Goldcylon
Brake Booster ZR-1/PBR ( gone from GM)..$200
Rear cargo moldings ……..$5ea-dbriana (right side only)
Fuel door assembly…..$25-Falconfling
Steering wheel (no air bag)…$50-Ifogot who
Turn signal/wiper/cruise switch…$40 Jarvis
Seats w motors and rails (no rips)..$500 falconfling
The prices do not include shipping, I only charge what the shipping is( no extra ). So if you call it here it's yours.
Please keep it out here what you want, Im getting PMed crazy.
We can PM shipping and payment info.
Thanks Kevin
Old 07-06-2008   #2
1991ZR1
Default Re: Parting out 1991 ZR-1
I'm interested in the following
Hood latches
FX3 computer
Left headlight assembly
Right headlight assembly
Headlight module
Power key switch and bezel
Sending you a PM
1991ZR1 is offline   Reply With Quote
Old 07-06-2008   #3
Zr1 Destroyer
Zr1 Destroyer's Avatar
If the passenger side is considered the left side I'll take the left side headlight assembly w/motor!
Zr1 Destroyer is offline   Reply With Quote
Old 07-06-2008   #4
I posted on the other forum at 156 pm as well and also sent you a PM
Ill take the switch and bezel ( Does it have a key?)
Also I want both the front left and right side marker lights
Also the rear side marker lights both sides
Does the FX3 switch include the harness
Please LMK Daryll
Old 07-06-2008   #5
Also can you send me a pic of the upper radiator shroud with stickers
goldcylon@cox.net
Thanks Daryll
Old 07-06-2008   #6
Polo-1
Lets see if this works, for pictures.
http://s7.photobucket.com/albums/y29...20ZR1%20Parts/
Old 07-06-2008   #7
Polo-1
Hood latches
FX3 computer
Headlight module
Sending you a PM
Daryll, I think 1991 ZR1 is 1st on the power key/Bezel and head light assemblies.
You are 1st for FX3/seat switches and harness not cut. and all side markers.
NO WIRING WAS CUT FROM THIS CAR... All finger nails inplace, thank JeffVette for that.....
Old 07-06-2008   #8
Kevin Im not going to argue But I was the first on the other forum to post in both the for sale section and the ZR-1 section for the parts I requested. Whatever you think is fair if the your telling me only the front and rear side markers and the FX-3 and seat switches with harness is availalbe I can live with that too bro. Send me a total and a paypal address. IF you deem Im worthy for the switch I will take that too. To make this clean LMK. Daryll
http://forums.*************.com/show...post1566196278
First to Post with the same list
http://forums.*************.com/show....php?t=2071343
First to post again about the same list
Old 07-06-2008   #9
Polo-1
Your right, 2:56pm my bad...
Power Key/radio bezel to you.
Kevin
Old 07-06-2008   #10
LOL ok I will I think I owe him a beer or too as well What will you need for shipping
Im at $90 for the front and rear side marker lights and the FX3 switches with harness. I do not want the radiator shroud. Maybe the oil cooler lines if they are still available? Is the radio bezel surround avail
Does the AC condensor come with all the ac lines as picd?
