Old 03-29-2019   #61
Scrrem
Scrrem's Avatar
Default Re: Fikse wheels
I’m running 3/8 spacers on my front FM5’s
Rich.
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-30-2019   #62
Originally Posted by Flyman 27 View Post
Did the tires rub in the front or rear?
How much did you have to trim the inner fender well?
There is an area in the rear wheel well liner that will need to be trimmed. I’ve got a new wheel liner loose that I can get a picture if anybody needs it.
Old 03-30-2019   #63
Originally Posted by G8nightman View Post
Got an update on my order. My wheels are getting closer to being doneAttachment 8866
Those centers are gorgeous,it would be interesting to know what Fikse uses to
get that finish,that has got to be the best looking surface finish I’ve seen on a wheel. I’ve got a machine I made years ago I use to put a brushed finish on a wheel and using a green scuff pad with WD40 almost has the same look but not the sheen. Fikse is the only wheel I’ve ever seen that has this look,it’s what makes the wheel unique and stand out from the other wheel manufacturers out there.
Old 03-30-2019   #64
G8nightman
G8nightman's Avatar
Please post I would like to see it.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 03-30-2019   #65
As some additional info, when I first put even 325s on the rear, I did have a rubbing on the inner tire at the wheel well. Over abrupt dips, I could hear the wheel rub behind me. So 345s exacerbate that. However, I converted over to both the DRM trailing arm and rear camber brackets. These helped to nearly eliminate the rubbing altho it will happen. Previously I would get out of the car and have a slight rubber smell. That doesn’t happen any longer.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-30-2019   #66
This is on the forward are on the liner,picture does help much you can get an idea where the spot is. On my car the rear tire will skin the inner backside of the liner occasionally but my car is lowered so it shouldn’t rub on a car at OEM height.
Old 03-30-2019   #67
The area you need to trim is the squared off area opposite the hole for the bolt. I only trimmed off the edge that stuck out. This liner is for the left side.
Old 03-30-2019   #68
RICKYRJ1
RICKYRJ1's Avatar
I bought a set of Alfa1 wheels in 19" front and back need to get some Mich SS also now
Old 03-30-2019   #69
G8nightman
G8nightman's Avatar
Thanks for the pic[emoji1360]
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-02-2019   #70
USAZR1
USAZR1's Avatar
The inner fender fenders on the later cars, have a few significant projections/nubs on the inside edge. These will cause clearance issues, also. On my 94, I used a little angle grinder to remove them. On my 90 & 91, the inner fenderwells didn't have the problem.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
