01-17-2020 | #61 | |
Re: Serious Concerns Over Parts Availability
H
01-17-2020 | #62 |
Thanks for the replies. I am taking a friend with me to look at the car and he is a pretty good mechanic, has a previous career doing Corvette bodywork and has owned several Corvettes although no C4s. Assuming it is as advertised and we strike a deal I will pull the trigger.
Thanks again. I will share picks if it happens. |
01-17-2020 | #63 | |
So far, knock on fiberglass, my 94 was never sidelined due to lack of parts. Fact that I live in the Wazooland made it possible since 2009. Even before, only headache I had turned out to be injector failure. Last edited by secondchance; 01-17-2020 at 06:43 PM. |
01-17-2020 | #64 | |
Get the ZR-1, drive the ZR-1, and enjoy the heck out of the car!
Evan
2024 Z06 SOLD - 1991 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
01-18-2020 | #65 |
David-
I started this thread and am surprised at how many responses it has gotten. My first question to you is why a ZR1? Knowing this I will be able to formulate a better response to you. I currently own 2 low mileage ZR1's. I love them both but probably would not have purchased the 92 knowing what I know now about expertise and parts availability. There are precious few individuals who really know these cars. Every year that goes by less and less parts become available. There are people who endlessly search the web to purchase as many of the theses soon to be extinct parts to either keep for their own cars or resell at crazy prices. I recently have had to deal with faulty tire pressure sensors (Which are no longer available) and a bad knock sensor circuit on the my 95's memcal chip which was replace by Marc Haibeck but not after considerable trouble shooting by me using a data logger and preforming many system tests and replacing the knock sensor. Anyway....as I have seen in some responses to your post, how willing are you to learn about the car yourself and work on it yourself and are there trusted service entities in your area that are willing to work on the car when needed? I just got turned away from a Chevy dealership when I brought my 96 Corvette LT4 to have the AC looked at, probably a bad compressor (I replaced the compressor clutch) and got turned away. They said because of parts unavailability they no longer work of C4s. There is another place here that just works on corvettes but it will be a month before they can schedule me an appointment. Also, if anything happens to your AC system, it will need to be converted to the new refrigerant. There are opinions regarding this and the parts to do the conversion correctly may not be available. When you check out the car, make sure everything works especially the secondary throttle system. Learn how to pull codes from the dash and AC unit to check for problems. Many codes can be turned off and take some time to re-appear. Make sure you take the car on an extended test drive. The headlights and Bose speaker amps are prone to problems. I replaced all the gears in my head lights myself and all the dried out capacitors on the Bose speak circuit boards myself. Make sure all the seat adjustments work and give the engine bay a good look over, make sure you know what a stock engine bay should look like to spot any modifications. I could go on but I think you get the picture. To elaborate on why I asked why a ZR1.... if you are looking at buying a corvette just because you want an affordable second fun car and have no interests in the mechanics of the car or working on cars or learning everything about the car, searching for parts (which can be challenging at times but its not like you are looking for parts for a model T) etc.... I would recommend looking at a Z06 C5 which gets you a lot of bang for the buck or maybe a 1996 C4 Collectors Edition or Grand Sport which are OBD II cars and also have new refrigerant so AC system can serviced. If you really want a ZR1, I would look for 93-95 model years for a variety of reasons.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 01-19-2020 at 01:04 PM. |
01-19-2020 | #66 | |
ECM Interchangeability DIS Interchangeability CDM Interchangeability Oh.....and guys and gals.....I suggested "get yourself a NEW Hood Support Gas Cylinder as the Stock Hood Support looses gas pressure in its old age. A New Hood Support Gas Cylinder will actually lift the hood back to the top if you lower the hood 6 inches. Ecklers Corvette Hood Support with New Outer Sleeve" This also applies to the rear Hatchback Lift Gas Cylinders.......except different but available Gas Cylinders ........With the new Gas Cylinders..... you pop the Hatchback Open Button and up it goes by itself.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-19-2020 at 11:19 AM. |
01-19-2020 | #67 |
Most of the work to be done on a ZR is pretty straightforward and can be done DIY. The only work I have someone like Pete do has to do w the cams/cylinder heads and block. Brakes, clutch, driveline, tuning, suspension etc is all stuff I can do on my own with good parts availability. Some of this I’ve also upgraded, like tires, wheels and brakes to newer generation components, ie C6Z.
My main concern is the DIS which so far has proven incredibly resilient.
01-19-2020 | #68 |
Thanks to all for responding to my question and an apology for taking the thread off topic. I should have started a new thread.
Left Dallas early Saturday morning and drove to check out the car I am interested in. To make a log story short we struck a deal and I will go pick the car up in two weeks. Car has been immaculately maintained so I am confident that it is in as good a mechanical condition as possible given the age of the vehicle. I look forward to learning more about the ZR-1 and learning from you all. Best, |
01-19-2020 | #69 |
Congrats! Let me know once you have it back to DFW, we should meet up.
Evan
01-24-2020 | #70 |
Always good to reread posts for those "ah-ha" moments. At 160k miles my LT5 was going through oil and it would usually not respond to the secondary's kicking in most of time. Passing smog (I lived in SoCal until end of 2017) was a bear. After disassembling the engine found the liner wear out of spec, unusual for an LT5.
When rereading this thread I saw Jerry's post about catalytic converter dust back flow wearing out the pistons, rings, and liners. The "ah-ha" moment was that I found the catalysts had structurally collapsed, sounding like a can of gravel when the exhaust manifold were handled. So there's the tie to my lack of performance when accelerating (blocked exhaust path at cats) and the wear on the liners (cat dust backflow). I'm one of those that had to replace all liners and rings. Headers are now in place so exhaust flow not issue. Thanks to the Net and people with experience and dedication to keeping the LT5 alive. Tony (Tnova) |
