Old 01-25-2018   #61
Default Re: Potential Fuel Pressure Regulator Solution
Cliff is it me or does that piece look more "Stock" than stock? It just follows the form factor better like stainless oil cooler lines. It looks like that was like it was suppose to... or meant to... look like as "serviceable" vs. non serviceable. GC
Old 01-25-2018   #62
Default Improved Fuel Pressure Regulator
LOL........I am not sure what you are thinking but this IFPR that Phil designed with the Allen Head screws is a very nice piece of work and is a perfect fit with the other Allen Head Stainless Steel bolts on the Plenum and coolant pipes.
And it is completely serviceable without removing anything else. The only item you would want to service would be the Delphi Fuel Pressure Regulator that Phil installed in the modified Stock Fuel Pressure Regulator Housing. I expect that to change out the Delphi would take a couple of minutes with only a small Allen Wrench.
Old 01-25-2018   #63
A couple of minutes IS a total win !
Old 01-25-2018   #64
The Delphi was rotated just a tad counterclockwise in the photo which only took a minute to loosen the Allen Head screws
It definitely is a thing of beauty
I was trying to hot wire the Fuel Pumps using the Fuel Pump Test Connection which for the early 1990 (first 500) Marc says resides to the right of the battery. Marc also said it is sometimes hidden. I removed the battery and yes......it is definitely hidden as it was nowhere to be found
So....to test higher fuel pressure I just removed the vacuum line at idle and got the 52 psi fuel pressure. Again......I have run into a couple Failed Fuel Pressure Regulators and they DO require removal of the Plenum to fix. NOT ANY MORE
DO NOT TOSS A FAILED FUEL PRESSURE REGULATOR
Old 01-29-2018   #65
Phil.......can I just keep this one
I have been driving every day and even a 100 mile trip.....
Perfect all the way.....NO ISSUES.....
Just let me keep this Improved Fuel Pressure Regulator on the ZR-1 for a while longer at least until mid April if possible as I will park this 1990 #72 for a while at that time.
Old 01-29-2018   #66
Jagdpanzer
Jagdpanzer's Avatar
Sure Cliff, keep it as long as you want.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-30-2018   #67
WVZR-1
It looks like the Delphi should be rotated just a tad counterclockwise in the photo which would take only a minute to loosen the Allen Head screws but I did not want to mess with this prototype as was not sure if Phil used Loctite or not. Did not want to loosen anything on this prototype as there was NO leaks when I received it
Dremel the bracket for nipple clearance I'd think. Orientation of the FPR looks to be fine.
Old 01-30-2018   #68
WVZR-1
No......it looks just fine because the rubber connector is bent.......It would only take a second to rotate counter clockwise with Allen Head loose which I did not want to loosen on prototype. You can see the nipple in right photo is pointed to far clockwise.
I'm thinking a couple minutes counter-clockwise and you'll have issues with the retention ring hardware. What was and what is isn't relevant. Look at the Lingenfelter adjustable in post #26.
Old 01-30-2018   #69
WVZR-1
OR you could have used the "Dremel" and been done before NOON
You need to remember it's an "engineering sample" that you were afforded the opportunity to "test drive" - that particular one is as it is!!! The likely hood of releasing the FPR and rotating it and compressing again into the cavity I believe creates potential sealing issues. The original Delphi using the snap-ring retention into a formed/rolled cavity I'm quite sure was susceptible to leaking when removed and reinstalled. I've had many 3800's that used that style of FPR.
Old 02-01-2018   #70
5ABI VT
Can put me in line ! not too long ago I started wondering if welding an fittings to the rails and installing my own adjustable unit was the way to go but I have no need for an adjustable unit.. this looks great =D>
