#61 | |
I love this car for sure! I smile every time i drive it. |
#62 | |
![]() Join Date: Dec 2003
Without the top valve spring to hold the valve closed like the new one on the right, the Bypass spring has the t-stat valve shaft at maximum extension. Bypass spring looks the same, 6 coils, same gauge wire. You probably see the same extension when you "cook" a t-stat to test it. Picture is sort of an optical illusion.
#63 | |
It does look like that top spring is missing which must have been by someone who wanted to maintain the recirculating function but have a wide open thermostat. That is the trouble of those thinking they can just remove the thermostat completely which cannot be done because of the resulting recirculation. They do not realize a lot of coolant would then always bypass the radiator.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-10-2017 at 03:03 AM. |
#64 | |
I think it was modified. Someone cut the coils & removed it.... at least I hope so ![]()
#65 | |
![]() At least the modification someone did to that left thermostat makes a lot more sense than eliminating the thermostat. I wonder how that modified thermostat performed when 100 deg ambient...that would have been interesting as the open area was definitely greater than a stock thermostat when full open at say 185 deg or a bit higher. That is a test I would like to do sometime leaving the recirculating function in place. I could take one of my older stant thermostats and modify it as shown on the left and measure that open area as a start to see what can be done compared to a stock thermostat. There WILL be more flow through the radiator and probably less radiator pressure because of the reduced resistance to flow as compared to the stock thermostat with a smaller Full Open area. ![]() Do you have any data on engine temperatures and ambient temperatures and other conditions running with that modified thermostat you removed?
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-10-2017 at 03:30 AM. |
#66 | |
#67 |
I test drove the car at temperature and there are some clear issues with the SuperChips PROM. It still backfires on decel and the fans run all of the time with the climate control off. It also seems to run rich. I will be ordering the PROM from Marc. Holy crap this car is fast-I still have a perm-a-grin from yesterday.
#68 |
The new thermostat is from Jerry and it does have a gasket on it. It is a little different of a design and has a rubber sharp lip on it. It appears as not having a gasket, but it is there if you look close. I used a thin scraper to hold the thermostat in while I got the housing in place. I then crossed my fingers that it was in place correctly. It doesn't leak, so we are all good.
#69 | |
I would throw that SuperChip PROM in the trash.....I just got my PROM back from Marc and wowie!!!! The car idles better, doesn't have the hard restart issue, no 1-4 shift, and seems to have more torque down low. |
#70 |
