Old 09-21-2016   #61
efnfast
Default Re: Nitrous
It has window and WOT switch
A window switch, as in momentary contact switch?
WOT switch, gives a shot every time you hit W.O.T.?
efnfast is online now   Reply With Quote
Old 09-21-2016   #62
Default Re: Nitrous
Set up for nitrous to turn on only when TPS reads WOT, starts spraying at 3500RPM shuts down at 6800 RPM; redline is 7200RPM. I also changed fuel pumps, filter, ohmd the injectors, and my O2 sensors are showing fueling is good in the base tune
Old 09-21-2016   #63
Default Re: Nitrous
Wet system is very brave on the LT5.
I have boxes of new NGK spark plugs for nitrous (Cold) if you need them.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 09-21-2016   #64
Default Re: Nitrous
I was just on the line w/Zex tech......issue for nitrous backfire is typically when the car is too lean......if I have fuel puddling in the intake at 3500RPM I have a serious problem; my A/F ratio on the car currently averaging 12.5:1 ....richest is 11.8
Old 09-22-2016   #65
Hog
Default Re: Nitrous
We are talking about 9-1/2hp per hole, you have gone above and beyond so for as safety measures are concerned.
The cooling effect as the Nitrous Oxide phase changes from liquid to gas inside your air intake would on its own deliver measureable increases, before the benefit of extra Oxygen and gasoline are accounted for.
Does this LT5 have Port Throttles? (I'm guessing not, but cant remember for sure)
I can hardly wait for your successes.
peace
Paul
Old 09-22-2016   #66
Default Re: Nitrous
Nope, they have been removed......
Old 10-24-2016   #67
Default Re: Nitrous
Ran the nitrous today; no explosions Car pulls, squats hard, pretty seamless with a 75 shot, can light the tires up from 2nd gear roll. Probably need to tune it on the dyno, will probably just jump to the 100 shot
I used a 180 ohm resistor to pull timing via the IAT
Old 10-24-2016   #68
Default Re: Nitrous
Something to keep in mind, while nitrous is cheap you spend about 60 per 10lb bottle, that will add up over time
Old 10-24-2016   #69
Billy Mild
Default Re: Nitrous
Sounds like a lot of fun.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
