#61 |
![]() Join Date: Nov 2013
#62 |
thought that was standard short hand.
#63 |
#64 |
fair point, well made and nicely presented. I'd forgotten that the ls7 was a sbc
#65 |
![]() Join Date: Sep 2012
My mistake. I thought it was a BB.
#66 |
![]() Join Date: Feb 2011
The LSx all have the same block dimension, but I took at as any v8 over 400 cubic inches to be a "big block" as the historical packaging generally had its threshold at about that size.
#67 |
I had a 70 1/2 TA that had a 400 small block (Ram Air III). If I'm not mistaken the "small block/big block" designation was only applied to Chevy engines, tho. But the Pontiac 400 was always referred to as a small block.
#68 |
396 was a big block back in the day, so displacement was not the determination for the designation. BB cylinder heads would not work on a small block and vice versa.
#69 |
I thought it had to do with the bore spacing?
#70 |
Well you could say bore spacing has something to do with it. Here's a very illustrative video of the difference. The name "big block" becomes pretty obvious.
http://youtu.be/LPZuEWli4gQ |
