12-28-2015 | #61 | |
Re: Windshield
I'm trying for an original reproduction (not LOF); if not, I will end up with the standard C4 windshield for $212. The guy I am dealing with is very knowledgeable and was sharing the difference with all the windshield brands out there. Most are from China, but a few are not and better quality. Not sure what Safelite and they would not say the brand; staying away from them (the ones over here anyway). I had all the info written down and called or went to so many shops until I got dizzy. Best wishes.
12-29-2015 | #62 | ||
Re: Windshield
Happy New Year Craig and everyone looking at this thread
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-29-2015 at 05:08 PM. |
12-29-2015 | #63 |
Re: Windshield
I remembered I had stashed a set of windshield moulding just in case. So, I dug up my stash and wanted to clear up removal/install procedure since I remembered what I wrote earlier may be wrong:
Above is the driver side side mouldings. Piece on the left (sorry the image is upside down...) is the first piece you will be removal after the weatherstrip is removed (we'll call it channel strip since this piece is shaped as channel to receive weather strip). Piece on the right is the trim piece. Above is the back side of the trim piece. Notice vinyl strip? I call his flashing since this flexiable vinyl strip is what keeps the water out. Separation of channel strip from trim piece is difficult because factory used double sided tape to hold the two before screwing. Also, if you want to truly maintain OEM look, careful removal of the trim piece is necessary not to destroy vinyl flashing. Above is the top piece (two pieces of powder coated aluminum rivetted together) with vinyl strip to keep the water out. I believe this piece is under the side trim piece but I may be wrong. I will edit after I take a look at my car later. Once again, careful removal is necessary to avoid any damage to the vinyl strip (flashing). When reassembling, if NCRS level reinstall is desired, use of double stick 3M tape is the only way to achieve correct look. I use double stick tape to attach vinyl pieces on the edge of the windshield and "A" pillar and roof structure first followed by side trim mouldings. Another layer of double stick tape is applied to the side trim mouldings followed by side channel pieces. I believe top trim/channel piece goes on top. Problem of achieving OEM look is water infiltration may be an issue due to reusing aged vinyl trim and make shift use of double stick tape. If this install is for the daily driver, I would not use vinyl trim and after the mouldings are installed, use masking take along the edge of trim moulding and windshield and fill the gap with silicone or black urethane caulking. Lastly, I recommend not to glue the new weather strip to the channel moulding. Weatherstrip holds fine without glue and compression from the top keeps water from entering. Only place to worry over water coming in is at two top corners between the weatherstrip and the trim moulding. I use masking tape to control the edge of silicone caulking and fill the gap after installing the top. I will add photo later. |
12-29-2015 | #64 |
Re: Windshield
Exactly the instructions I was looking for
I assume you remove the windshield after all the moldings are removed? Is it stuck so you push the windshield out from inside? Oh......How did you come by the extra moldings? I have a set of standard 1990 (L98) front window moldings and assume those moldings are installed the same and are the same as window moldings on a ZR-1? I see exactly what you are saying about the double back tape keeping the two side pieces together and hiding three screws under the double back tape. The top molding appears to not have the hidden screws. On the side moldings there are 4 screws for the top powder coated molding not necessarily the same location on each molding. The inner piece (after cutting the double back tape) has 3 screws not necessarily the same location on each molding from car to car. The Top piece has one set of screws and they are located the same on each top piece from car to car? Happy New Year Yun and everyone looking at this thread
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-30-2015 at 02:15 AM. |
12-29-2015 | #65 | |
Re: Windshield
The guy that I am using used to work for Safelite and now has his own business. He said that if I don't decide to use him, there is a guy from Safelite that he would recommend that is just as good as him and been in the business for over 20 years and did a bunch of C4 windshields. I'm sticking with this guy after visiting him several times and seeing how meticulous he works, and how clean his shop is. I don't want the mobile job at work site or in my garage. To answer your question before edit, I tried to have this guy sell to other members that I knew were looking for the GM NOS stuff. This shop had a bunch he bought from GM years ago (around 60 sets), but has only a few left. Sorry, he would not let me refer him and said he has to keep the remaining few for his actual customers. I had to respect that and he would not sell more than one knowing more valuable than gold (very expensive if you find it). I hope you find an NOS one, but even new and sealed there might be cracks and wrinkles I am told. My guy said don't open as my original is very nice and he thinks he can save it; I am told he will not be able to no matter how good he is or takes his time. Happy New Year and best wishes! By the way, I might have some good news about your code tool and late model adapter. I have to confirm first.
12-29-2015 | #66 | |
Re: Windshield
As always, thanks for sharing so much detail of your experience with this issue. Every little bit of information helps.
12-30-2015 | #67 | ||
Re: Windshield
I came by a regular 86 Corvette that got bar-b-q'd. Went to his house and removed all the mouldings. Quote:
As for the top piece, whether it can be transferred from another car without re-drilling screw holes, I am not sure. You are correct, there are no hidden screws. Over the years (93, 2012, 2014 and 2015) I messed with 4 ZR-1 (91, 94, 90 and finally a 95) window mouldings. Seems to be getting better at it... When I am over this rush at work, I will take time and, perhaps, start a new post with pics and more detailed information. Happy new Year to you all also! Last edited by secondchance; 12-30-2015 at 09:31 AM. |
01-04-2016 | #68 | |
Re: Windshield
That tool is soooooo handy. Now to find a couple of those plastic covers for the ALDL Connector under the Drivers side panel Back to Windshields.....I got something going on and will post later if it works out |
01-04-2016 | #69 | |
Re: Windshield
Can't want to hear your secrets.....
01-04-2016 | #70 | |
Re: Windshield
So....how do you like the 95 compared to a 91 or a 90? I do know it is a lot of fun keeping the LT5 stock after a Plenum Removal to clean up Injectors, Starter, Vacuum System. The LT5s are soooooo reliable after fixing a few minor issues. One thing I do is thread and screw in an Allen Head Aluminum Plug in the Injector Housing TB Coolant path leaving the outside appear stock WITHOUT Hose Clamps on those TB Coolant hoses. And I add one HIDDEN Plug in the return of that TB Coolant to the coolant reservoir. And Carter Bling...........And Differential Drain Plug Installation.....And....Darn....here we go again but I still call them stock
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-04-2016 at 11:37 PM. |
