Old 04-27-2014   #61
Default Re: Headers Installation...
What DID they use to hold the gaskets in place in BG???
I used a smear of the RED, HIGH TEMP RTV on both sides of the gasket to stick it in place. That center bolt serves as a convenient hanger to hold the gasket in place. Just have to be careful not to accidentally scrub it out of place while situating the header.
Old 04-27-2014   #62
Camshaft Position Sensor
Knock Sensor
Below the Knock Sensor would be the Oil Level Sensor mounted on the Oil Pan if the LT5 is a 91' or later.
Now.....do not clobber it all up trying to fix it
Old 04-28-2014   #63
Karl
Karl's Avatar
I have my top end done, less the.cylinder heads and what a difference!!!
The obx headers hit the steering rack and required a ding in the #1 tube to clear. I don't like it and plan on having the #1 tube reshaped. Pete showed me some Jeal and Watson headers and they all needed a ding to clear, but the obx a little more.
This car has some balls now and is quite impressive. I will have some new dyno numbers soon to post.
Good luck!
Old 04-28-2014   #64
Good luck!
Amazing what a little more air does for these motors, isn't it? BTW, my Watsons required no mod. The tubes are 1 7/8" on these, which I think has no real affect on power.
Old 04-28-2014   #65
Karl
Karl's Avatar
The obx are 2", and I am most likely mistaking the brand of one of those headers in petes garage.
Old 04-28-2014   #66
Karl,
No I think you are right. He has Jeals and Watsons there. Some of the interference is vehicle specific depending on how the motor is positioned.
1/8" can make a diff.
Old 04-28-2014   #67
efnfast
My OBX rubbed on the steering shaft. Had I known this before I had them coated I would have dimpled them. Instead, we shimmed the motor mounts. Don't go too crazy, there ain't much room under the hood to lift the engine.
Old 05-02-2014   #68
4-cam
Wouldn't be any fun if it bolted right in, then any body could do it. It seems like I always have to be a bit more creative when working on the Z. Nothing seems to go as planned but I think thats why we we all seem to enjoy these cars...... there just little different if you know what I mean.
4-cam is offline   Reply With Quote
Old 05-08-2014   #69
Z06scentair
Z06scentair's Avatar
Bolt right in... Dream on Schrade.
Where's J Becker? What pipes do you have with your automatic? Anyone else been here???
So we're still working on clearance for the shift linkage. As little milling / modification as possible here.
The PE 3" pipes are designed for a C4, and the D side pipe even has an angle recessed for an LT1 with a 4L60e - I got a CLOSE fit, with no milling. But it was too close, with heat a consideration. The tranny control module has a temp monitor w/ warning, for the tranny fluid heat.
So I decided to wrap the header-to-X-pipe sections (oops - gave away the header wrap excess ), and the wrap made for contact with the shift linkage - the rubber boot / sleeve. The additional wrap might also quell some drone...
For the 'Pittman' arm 'A' at the shifter, I can take some bend out, without affecting the shift shaft range of motion. Getting 'Park won't be a problem - it gets the 'P' detente. I never go there anyway - e-brake for parking...
I also zipped off about 1/4" - 5/16" off of that stud for the cable end, along with about 1/3 of the bolt itself, for additional clearance.
Then the rear cable stay bracket has to be given about 1/4" additional recess at the Blue. Bending THAT bracket is out of the question - it has re-enforcement in the 'square'.
Looks like you have it whipped into shape Chuck!
They sell some velcro heat sheild you could wrap the linkage with. It comes in a few diameters to fit each subject matter.
Made by a company called DEI??
If you could removed a small section on the header wrap, would it give the clearance needed?
Z06scentair is offline   Reply With Quote
Old 05-08-2014   #70
Schrade
What's up Brad...
I had clearance without wrap, but it was too close. I wanted heat protection.
It will clear once I get the bend in forward, and the bracket recess opened up inward toward the pan.
#1 cleared the steering shaft. Only things I see now is the dipstick, and O2 reach.
Everything ELSE should bolt in.
No chance of beach time next week there Brad? Gonna' try to get up with J Fletcher and do some range time one day. 9 beds; only me, sis + stepmom... Gonna' squeeze a few .30 Carbine, M1A .308. My Rock-Ola is a REAL tack driver, ESPECIALLY for .30 Carbine...
