Old 01-19-2014   #61
Schrade
Default Re: 368 LT5 Drinking oil
Before I pulled the secondaries, I started vac integrity tests in sec vac system here, starting post #362 http://www.zr1.net/forum/showthread.php?t=21439&page=37
Yup - seen THAT before...
... and for NOW:
Re-assembled, with gear oil on the eccentric, and grease on the end of the armature shaft WATCH FOR A WASHER ON THE END OF THE ARMATURE SHAFT.
(AND THIS IS THE GOOD STUFF)
Pump lid NOT sealed yet...
bench (tire ) test dialed in (jumped straight from battery - more on that momentarily here)
vac nipple blocked; switch killed pump right away
and this question, about vac test without plenum re-installed, is answered
cables run to P side fenderwell, jumpers on vac pump (never mind the Guinny Stoudt - NONE for you! )
This juncture shut off right away, and held
reservoir evacuated in 3 seconds and held
Old 01-19-2014   #62
PhillipsLT5
PhillipsLT5's Avatar
Jerry has you going in the right direction, were the injectors new or rebuilt units from FIC, I do think they will warranty any bad units, I did here of trouble with rebuilds, I would suggest to yank secondary's and have Marc burn you a working chip for that
Old 03-11-2014   #63
Mitsumark
Ok fellas an update..I changed the oil and switched to Mobil 1 15w50..Ive driven 2200 miles since my last post..I have also replaced all the plugs at that time so the plug pictured below only has 2200 miles on it..Oil consumption has been cut down since the last oil change..Probably cut in half..However it is still burning oil at an alarming rate(1qt 600miles) as seen by the plug below and it still smokes faintly at idle,and under moderate heavy accelaration..It does NOT smoke at all on decel in gear..Now remember earlier I ran compression test and it came back with great numbers..Since then on top of the plugs and oil change,I replaced both 02s,and both PCVs again just for good measure..My PCVs and piping were loaded with oil after 2200 miles again also..I have checked high and low for vac leaks and have found none..Car still pulls hard in every gear with no misfires..Idle is stable when sitting still however she hunts from 900-1500 when rolling in neutral until dead stop where she evens out at 900..I know from reading the plugs it is running pig rich as they are loaded with carbon,but its looks like oil is present also.All plugs look similar with 3 looking a bit worse than the others.Hunting idle,pig rich,burning oil..Is it possible I have a leaky plenum gasket that is undetectable?Ive triple checked spraying carb cleaner around the base of the entire plenum,inbetween runners,underneath..No change in idle..Can I be pulling oil into the injector housing somehow?What other way can oil be making it in to the combustion chamber?Im at a loss and Im extremely close to selling this car..Pic coming in 5..
Mitsumark is offline   Reply With Quote
Old 03-11-2014   #64
scottfab
scottfab's Avatar
I'm not really sure which problem you're after, oil or possible plenum leak? I don't thing a plenum leak will cause higher oil consumption.
Staying with the oil for a bit. What happens if you drive for a bit and keep the rpms low? Does it still consume 1qt per 600mi?
Scott
Old 03-11-2014   #65
Mitsumark
All plugs are ugly..Oil comsumption is bad regardless of how Im driving as proven by smoking at idle.
Old 03-11-2014   #66
Polo-1
I'm no Vette Doc. But looks to me your I need of a tune bad. Your washing down your oil with way too much fuel and drinking it.
See if you can get help with a stock chip and drive it. Yes, you will leave power out. It will still run fine for testing.
Old 03-11-2014   #67
Mitsumark
That is what I wish I can do..This all started with the installation of a canned tune installation..The car had a chip burned specifically for this build and I had it flashed over like an idiot with the new tune..I don't know if a stock tune would help me as this car is pretty modded and also has intake cams..I don't have access to a stock chip either.Theres nobody in NJ that wants to touch it.. Seems all the LT5 know how's are in Chi-town.I'm definitely in over my head..
Old 03-11-2014   #68
Karl
Karl's Avatar
I am no expert but why not just get another chip or have yours flashed again and see if that fixes the problem. After all you said it started when you changed the chip so there seems to be your problem.
Good luck!
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 03-11-2014   #69
Mitsumark
Very good point..Reason is I never would have imagined a tune to be so out of whack that it would cause oil consumption issues..I also didn't want to write over the existing tune as it was expensive and I'd hate to do it if it turns out it wasn't the problem..I know it's a lot to ask but if any of you would be kind enough to loan me a stock 91 chip for testing for about 2 weeks I would be extremely great full..Ofcourse I would cover shipping both ways..Sorry to come off hard faced but I'm desperate as I love the car and I want to get to the bottom of it before its to late..
Old 03-12-2014   #70
Polo-1
[QUOTE=Mitsumark;197786]I don't know if a stock tune would help me as this car is pretty modded and also has intake cams..QUOTE]
My 402 cube with both stage ll cams ran fine with a stock chip. I would think we have a brother somewhere near by that cam help with that.
