#61 |
#62 |
Lol if you were in AZ I'd bring the Tech 1 as well. Yeah NC is a little far. GC
#63 |
If that's idle, I think your TPS VOLTAGE is too high.
#64 |
Idle TPS voltage was good there Dominic - about .54 - I had just calibrated a few weeks ago, when I started this investigation http://www.zr1.net/forum/showthread.php?t=20793.
1.6V is where the hesitation and lope kicked in, and voltage jumped from 1.6 - 2.4, in sync with the lope. Could NOT get smooth rpm increase at that point in throttle upswing. |
#65 | |
#66 | |
![]() If I could send the last recording I made, I think someone with DM could see something, even tho' I had some of the wrong parameters set for monitoring... If there had just been ONE CODE - even a History one... Last edited by Schrade; 10-18-2013 at 11:36 PM. |
#67 |
Is there a vacuum issue potentially with the CC cover / seal? If there is vacuum there, and it's leaking, what would be the manifestations?
Hesitation perhaps??? |
#68 | |
ed.:
I'm gonna' solve this Mother&^%$ !!! OK here; we left off of this 'Hesitation' thread @ spark plugs and wiring. That's when the Top End Re-finish work started. So spark plugs are replaced (along with a little ancillary top end housework ![]() Next in the FSM diagnostic for 'hesitation' is the chip - see below. With Marc's chip installed, for high idle coast-down and lower temps trigger, and then his re-coded chip for secondary vacuum deletion, I can count THAT step OFF as well - CORRECT? So that takes me to TPS function test again... Quote:
#69 |
Chuck,
What happened to the high idle issue? Has that been addressed because I thought you had determined secondary blades were off? With the "hesitation" when does it happen? Just off idle? At small accelerator changes? |
#70 | |
Starting is MUCH quicker now, than before the top end cleanup began. Cleaned up electricals and contacts, and dirt removal, and injector nozzle cleanup has made a significant difference. OL and CL idle quality is flawless (can't even tell when it goes CL), and will obviously make for easier diagnosis of the hesitation issue, which has NOT changed. New vid just now (uploading to Y/T). Erratic response starts @ :26. It's hard to slowly raise throttle by hand... http://www.youtube.com/watch?v=rsKFOiNpLXk IMMEDIATELY when throttle comes off idle, it becomes erratic, until 'around' 950 rpms / ? exact TPS volts / ? exact % Throttle Opening, then it's smooth again. If I can get 'the factor' at it's critical point - that is, where the increase is pushed 'over it's response edge', it should stick out in the DataMaster histogram. I need some way of MECHANICALLY increasing the throttle, in TINY increments, to get to 'the factor's threshhold'. The idle stop screw would be perfect, but it's too difficult to access, with all the components in place... RPM Transmissions gave a listen to the buzzing TPS http://www.youtube.com/watch?v=hujg7xtlC38 and said it's normal for the Fluid Pressure Control solenoid to buzz, and probably isn't related to the hesitation coming off of idle. Last edited by Schrade; 12-10-2013 at 03:36 PM. |
