Old 02-14-2012   #61
Default Re: Al and Pete Fuschion - First Sounds
What about re-purposing the secondary throttle. Maybe Carter could make up a
flange w the shaft and butterfly installed. Then add actuators like old vacuum advance cannisters. Although exhaust environment will be tougher than distributor.
I found a shaft & butterfly kit in 2.25, 2.5 and 3 just need the ID of the Tips to know which one to buy
Vacuum Actuator would be easy to find, then make a arm for the shaft for open close and mock it up
Old 02-14-2012   #62
I think a sample of the TPS voltage to an OP amp driving the electrically operated gates...is a very possible alternative, should the vacuum gates prove difficult or expensive to attain. Hmmmm.... Do I hear an article for the next issue of the Registry coming up? Or, maybe a "show and tell" seminar for the BG gathering????
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-14-2012   #63
HAWAIIZR-1's Avatar
I have to wonder of QTP would be willing to sell just the gates sans the electric motors. then you could make your own Vacuum setup.
Although it would be cool to have the electrics if you could get them to work based off of throttle..
YEs the Z)6 mufflers are somewhat hard to find, but we are actually looking for RPO NPP which was avail on Z06, ZR1 and GS as well as an option on regular cars now.
I think if we could find the shaft and Blade int he size needed it would not take much to make them
Jeff,
Thanks for the tip about the NPP and I see that there is a lot more available. They all want too much, but obviously some can get lucky to get a decent deal on them. There is one speed shop in CT that is trying to buy all that he can find so I might just give up on the NPP option.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 02-14-2012   #64
ScottZ95ZR1
ScottZ95ZR1's Avatar
There's an old thread from 2005 on the other forum where Ken Reeves modified his B&B and here are a couple pics of his set-up.
Here's a link to his thread: http://forums.*************.com/c4-z...0&ref=esp-link
Of course you will have to edit the URL in your browser because reference to that forum disallowed here.
ScottZ95ZR1 is offline   Reply With Quote
Old 02-14-2012   #65
HAWAIIZR-1's Avatar
Thanks for sharing. Actually, I wish there were a low cost way to gut out my B&Bs to remove the restrictor plate in the version 3 mufflers and I would just put the X pipe on and call it a day. This is a cool, low cost looking more for the person with talent and equipment to mod themself.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 02-14-2012   #66
http://forums.*************.com/c6-p...-mufflers.html
Looks like a vacuum advance cannister would work based on the above pics.
Old 02-14-2012   #67
I have ordered 2 Vacuum advance Actuators like above.. they were $4.53 ea
Old 02-14-2012   #68
The link I posted is for 2 sets of Z06 muffs here in Chicago.
Old 02-14-2012   #69
Yeah I PM'ed him
Old 02-14-2012   #70
1990 quasar blue
I want to be sure so, at the risk of sounding a little slow. Will the npp tips off a non zo6 work just as well?
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
