#61 |
Drove it to work today..Smoke was down to much less than yesterday..But still present..It's weird..I can stand by the tailpipes and at times there is no smoke at all for 1-2 minutes..Then it's like the car burps and a few smoke puffs will come out..I swear with the lumpy idle and the Blue smoke occasionally,,I honestly think it could be something just throwing everything outta wack(AFRs)..Today I noticed the smoke was much more Grey and every so often it would turn Blue..It's like it's running pig rich and washing down the cylinder walls..What's throwing me off is I can't smell any fuel in the oil at all..I don't know..It was nice to drive it today..Had quite a few looks from some dudes as the car sounds menacing in person..Also had a chick in the next car over give me a dirty look and roll up her car window..I'm thinking she didn't appreciate the stinky exhaust..I don't blame her..It does stink
#62 | |
It can work how ever you want it to work. Just takes some ambition to get there. If you want to get your car fixed you can get it fixed. It may take some time but ultimately it can be done. If not, jump ship and sell it.
#63 |
not everyone is willing to put in the....lets call it dedication.....it takes to own one of these
#64 | |
![]() Join Date: Aug 2006
I sense that you are about to throw in the towel. I can only imagine the frustration you must be feeling. I chased pre-ignition rattling for 5-6 years and eventually tracked it down to bad injectors. In your case, I am no LT5 guru but I can't help but think something is forcing or allowing oil into the combustion chamber. If I was in this situation, I would pour a can of BG K44 into the gas tank when near empty and add about 10 gallons of gas then drive revving up to perhaps 3,500 to 4,000 rpm before shifting. Please note that this is what I would do. BG K44 is a fuel system/combustion chamber cleaner and hope would be, if piston rings are somehow sticking due to carbon deposit, fuel additive/carbon deposit cleaner would un-stick the ring. Like I said, I may be wrong but at less then $25 per bottle, worth a try... Also, notice any coolant loss? Or notice contaminants in the coolant? Check your oil dip stick. Is it pushed up? If so, sign of pressure build in the crankcase. Last edited by secondchance; 04-10-2014 at 10:34 PM. |
#65 |
![]() ![]() Join Date: Feb 2010
Without re-reading the previous posts....Did you put the old chip back in and evaluate the oil issue?
#66 |
![]() Join Date: Jul 2007
He can't I believe it was over written with the new stuff
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
#67 |
Where did the chip come from? Was it supposed to allow for moving the IAT?
If you move the IAT forward, and if the calibration does not compensate for that, the ECM will always see a lower Intake Air Temp causing it to richen the mixture. Frankly I think you're giving up too easily IMO. I would definitely look at unbolting the IHs. Pretty easy and easy to put back together.
#68 |
![]() Join Date: Jan 2009
Yes, I think that is what he wrote. If it were a stock displacement and configuration LT5 then a standard chip as issued from GM would work as a baseline for isolating the issue. As it is someone will need to spend the time and/or $ to get to the bottom of the smoke issue.
My gut says it ain't the chip though. Something happened during one of the mods such as has been mentioned, a void in a gasket or ?????? Mark, have you tried running the car with the oil at the ADD line of the dipstick? That is, wait overnight and check the oil. Is it at the ADD line? If so,. go for a drive, see if it burns oil at the same rate. I say this because that is what I do and it lowered consumption drastically. I only add when the level goes below the line. I just remembered this. Some burning on my car is normal since it is a 90 and does not have exhaust valve seals (by design). By running ~1qt low the consumption is lowered. On average I go through a qt every four tank fills IF there has been a lot of WOT.
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 04-11-2014 at 04:55 PM. |
#69 |
![]() Join Date: Dec 2007
Where in NJ are you? Do you want to sell the car?
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
#70 |
![]() Join Date: Mar 2007
Dominic you have a copy of my chip from the 91 368 that I have.....this is the same chip he is running. I thought he called you
