Old 04-25-2021   #681
HAWAIIZR-1's Avatar
Default TB removal and then some!!!
Hey Tom,
What was the condition of the inside of your coolant crossover pipe? Mine was rusted inside. My friend in Japan had coolant squirting out from pin holes due to rust.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-25-2021   #682
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Hey Tom,
Craig, the pipe is absolutely fine on the inside...just that one area that I repaired....but now you have me thinking about this...I will tape off the ends and fill with water and see what happens...
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-25-2021   #683
Roadster
Roadster's Avatar
Craig....just some minor surface rust...should have checked better before I painted....lol....will get some sandpaper and tape around the head of a long screwdriver and sand the inside of the pioe....just to be sure....20210425_145430.jpg20210425_145451.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-25-2021   #684
HAWAIIZR-1's Avatar
Originally Posted by Roadster View Post
Craig, the pipe is absolutely fine on the inside...just that one area that I repaired....but now you have me thinking about this...I will tape off the ends and fill with water and see what happens...[emoji16][emoji16]
Tom, That is good news. I think you will be okay and mine was just sitting too long and maybe too much water (distilled) with 50/50 mix. His was spitting out the pin holes only when pressurized. Luckily I had an extra crossover pipe to send him at the time. I am going stainless from Phil. When I move back this will be my last before retiring so no more sitting Z and then some......
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-25-2021   #685
HAWAIIZR-1's Avatar
Yours is beautiful compared to mine a few years ago.
Image1619377575.641845.jpgAttachment 1
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-25-2021   #686
Roadster
Roadster's Avatar
Good choice on the stainless....Phil does great work....glad to hear retirement is getting closer for you....will be 5 years in June for me....and that has gone by really quick.....
Attachment 15173Attachment 1
Wow....yours is really destroyed...glad you are replacing.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-25-2021   #687
HAWAIIZR-1's Avatar
Yes Sir! I am 3-5 years away from retirement. Yep, I already replaced the one shown.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-26-2021   #688
Roadster
Roadster's Avatar
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-26-2021   #689
Roadster
Roadster's Avatar
Someone just mentioned to me that the JB Weld will eventually break off from the repair area in the future and cause problems.....as you can see...the area circled is the repair area I sanded down after taking this pic....I can drill it out and round off that area...and just leave it opened without the JB Weld.....as it will be covered by the hose down to the straight line shown...as we all know....which won't be leaking when attached...
Any thoughts on using the JB in the cooling system???
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-26-2021   #690
Jagdpanzer
Jagdpanzer's Avatar
Should be no problem if it's on the outside.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
