07-10-2012 | #601 |
Re: LT5 Assembly Project
Lee, I have the same issue with my defective rear tires. After Pete's work, I just can't keep them from spinning every single time I drive it!!!!!!
07-10-2012 | #602 | |
It sounds like your really complaining about all that power. Pull a couple of plug wires!
07-10-2012 | #603 |
It's just aweful!!! Makes me want more cubes.....
07-11-2012 | #604 | |
07-11-2012 | #605 |
Lee,
Sounds like we need to add fuel at idle and lean out cruise. BLMs will always show 128 at WOT because you are now in Open Loop. WB O2 is only way of telling what AFR is at that point.
07-11-2012 | #606 | |
I thought that you need to remove fuel to get to 128.. I always forget, since I have a program I created that does it automatically I never remember the actual formula without looking at my code... LOL
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 07-11-2012 at 09:03 AM. |
07-11-2012 | #607 | |
What do you recommend for someone wanting to add WB O2 to their car and do you need to install dual bungs and have dual O2 sensors? Thanks, Craig
07-11-2012 | #608 |
for an accurate reading, before the Cats.. if you can I feel 2 are better then one..
07-11-2012 | #609 |
Thanks Jeff. I thought so and a friend said only 1 side really needed but it seemed you need two because even now with tuning it was found I have a problem on the right side with leak causing lean conditions. When I put my headers back in and install X pipe etc. I thought a good time to have the shop put bungs in even if I plug them for now, but could use when doing the dyno tune with WB O2s. I found one the Innovate system with dual O2s, but very pricey.
07-11-2012 | #610 |
out in the country/corn fields this morning on the way to work.....stopped revd it to 3K dropped the clutch and the car did a water box style burnout without using the brake, just sat and smoke the tires....lovin the car...
Every Z needs porting and cams...
