Old 03-24-2011   #51
Default Re: Ready for the oil catch can...
All you need is the 6AN SS braided hydraulic hose and some specific aeroquip reusable hydraulic fittings.....a vice and a couple cresent wrenches....oh...ya...a hack saw but a small hand held 4-1/2 inch angle grinder (with 4 inch steel cut off) works best for cutting the SS braided hydraulic hose
It takes maybe all of 10 minutes to make two hoses to any length you like. I will (maybe tomorrow) go out and redue some 12 AN SS Braided Aeroquip hose I have made up with pictures for whoever is interested to see how it is done. The SS braided hydraulic hoses and hydraulic fittings are good for over 1,000 psi
Taking orders there? Im in Maybe a direct fit into the cans... No Nipples
Old 03-24-2011   #52
Using 6 AN SS Braided hydraulic hose
Of course...direct fit...what is that can female thread again
I am thinking if it is 3/8 NPT then this 6 AN x 3/8 NPT will work perfectly...the side fitting will be
the top fitting will be
Now we are talking....... Only potential I see as a potential problem is chaffing above the coolant outlet pipe looking at Jeffs pic
Old 03-24-2011   #53
Aurora40
Aurora40's Avatar
They will be under vacuum, not pressure. So make sure they won't collapse. Hydraulic hose also isn't necessarily that large in internal diameter, as volume of flow is not the main concern.
Bob Saveland
Former owner of #2517
Old 10-01-2012   #54
Paul in SC
Paul in SC's Avatar
I know this thread is a bit old, just wanted to hear if anyone has updated info on results (oil collected over time), benefits/problems, new products, etc.
How about use on 93-95s?
Thanks,
Paul
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 10-01-2012   #55
Scrrem
Scrrem's Avatar
Thanks,
Paul
Paul,
I just got mine installed last April, I check mine about every third or four time I take the car out, I have been getting 2-3 tablespoons of oil everytime I empty it. Not sure of any benefits other that keeping that oil out of the plenum.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-01-2012   #56
I don't have my web host anymore so some links will show up broken..
I will reload some pictures for use in posts
Old 10-01-2012   #57
vilant
Got a noob question. I have a 90', and when I took the air intake off, I noticed a little bit of oil in the plenum. Is that normal? I know the reason you add an oil catch can is to stop that. But, I don't see a "factory" oil catch can. Why didn't GM put one in. Did they design the engine knowing it was going to suck in some oil and it would just burn off?
Joe
1990 Bright Red ZR-1 #2599
Old 10-01-2012   #58
Fully Vetted
Fully Vetted's Avatar
I was wondering the same thing. I have a oil catch can that the previous owner installed and it does a great job but why didn't GM install one if it's such a big problem?
Old 10-01-2012   #59
scottfab
scottfab's Avatar
Gezzz what a beautiful color for the LT5 !
It's either chrome or the red for me when/if I do it.
Scott
Old 10-01-2012   #60
Thanks Scott..
I I love that red and it is fitting color for the Heart of the Beast
