03-13-2009 | #51 |
Re: Emissions retest another failure
I'm with you! VA seems to get stricter every time I take my car in... The other kicker is that newer cars don't even need to do the sniffer test at all. And of course the biggest kicker is that the jerks in Richmond who pass these laws don't even have to abide by them, it only applies to Northern VA!
03-13-2009 | #52 |
I hear you Ron thats why I gave up and went another route. Its hard to stay in complaince when the standards are a moving target.
The new cars are a joke to test, all they do here is plug the car into the OBD II scan port. No code no issue right. Well I know those codes can be removed at the PROM level.
03-13-2009 | #53 |
cant one apply for a varience in va .plea your case with the supporting data from when our cars were built . one would think that,even they would have to alter the figs to match when the cars were built . either that or file suit to get a historical designation . i know its a pain in the keister but would think they either have to do that or buy your car . moving the laws to obsolite cars should be a crime .
03-14-2009 | #54 | |
1991 ZR-1, Black, Black, # 541 |
03-14-2009 | #55 | |
Re: Emissions retest another failure UPDATED
03-14-2009 | #56 | |
03-14-2009 | #57 |
A little exaggerated I think about the Texas emissions test. The results are totally computer generated. They have to be passing it as an antique.
03-14-2009 | #58 |
I had issues getting mine to pass here in CA. I did two things, went back to original Delco plugs (had Bosh in there when it failed) and I did a top end clean to get rid of the carbon build up. It passed just fine after.
-Nate |
03-14-2009 | #59 |
Funny you say that, i've 'Always' found Bosch to be absolute junk in the engines i build. They can't be 'that' bad, but i've had no luck with then what-so-ever.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
03-14-2009 | #60 |
i agree with ryan on the bosch fusion plug .being a plug nut (i try them all)car ran like junk. put in some E-3s and the idle was smoother than its been in along time,.ive also done the seafoam clean and couldnt believe the junk that came out of the pipes .
