Old 11-21-2009   #51
ZR1Vette
ZR1Vette's Avatar
Default Re: Can I get a lift?
Ok, now I am at the WTF do I do stage, 2Kpounds of metal in the driveway, directions are somewhere in the belly of this thing. There was a stray bolt sitting on the top.
Oh, and a nosey neighbor stopped and asked what it was, I told them it was my new steel reinforced bed.
The bolt..probably from on shipping pieces...the end metal brackets are bolted to the runners (metal decking) and they do come off on occasion. Start unpacking...you can remove the wrap, then most everything that is below and above the decking that is bolt to the end packing brackets. the columns weigh about 100 lbs each so you can move. Now...the decks are another story...one without the ram weighs in at 300 lbs and the one with the hydraulic ram weighs a little over 400 lbs. Unless you have some strong back weak minded gorillas suggest getting a engine hoist...works great...also some hoist straps (nylon type so you do not scratch the decks... strap a mid point and lift top deck slightly and then unbolt from packing brackets. Next do the lower deck.
This is a much better assembly guide than the one that comes with the lift>>
http://www.gregsmithequipment.com/Articles.asp?ID=331
Read over first to become familiar with the assembly process and if you have any questions just let me know and I can walk you thru...suggest you have two others help you with the assembly... Took Phil, Rich and me about 5 hrs to assemble (learning curve plus it was HOT so lots a recuperate time).
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 11-21-2009   #52
Former Illinois state deadlift record holder @ 730lbs....should be good, also bought forearm forklifts.......should be interesting
Old 11-21-2009   #53
Ccmano
Ccmano's Avatar
Sorry Lee, Not going to be able to get over there today. We have too much last minute packing and running around left to do. Hope you get enough help to get the thing done. Can't wait to see the pix of it up and running in your garage.
Good luck
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-21-2009   #54
No one showed, Got the post in and everything so far.....moving the 440lb ramp next.....should be exciting.
Old 11-21-2009   #55
All the heavy $hits done, you guys can come over.....
Not fun as a one man job! Just me a floor jack!
Old 11-21-2009   #56
Kb7tif
When there a will theres a way.. Trust me. You will get it.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 11-21-2009   #57
phrogs
phrogs's Avatar
you didn't blow a gasket did you?
JOHNNY P
Currently own
Old 11-21-2009   #58
Hey lee, Who was suppose to come and help?
Old 11-21-2009   #59
Pretty much an open invite......Hans had to pack..been there so no big deal......doing this solo is possible, but sucks.
Old 11-22-2009   #60
Toyvet1
Lee did you get it all assembled today. Leveled ? Where are the photos.
Toyvet1 is offline   Reply With Quote
