Old 12-27-2008   #51
robrtr
Default Re: Who Needs Friends Like these
It has been loaded on the trailer, and loaded off the trailer and put in the garage. All of maybe 1,000 feet. The car idles fine,and loafs around fine. It will probably never see the street, nor have the secondary system open.
When I had my low mileage '92 (8000mi) inspected by a corvette expert here in MD, he suggested I always drive it "key-on",and to "hit it hard" every so often, to make sure the secondary injectors get some use. He thinks that will prolong their life?? Of course, my '92 is a 'daily driver' compared to yours.
robrtr
'92 #225
Black/Gray
robrtr is offline   Reply With Quote
Old 12-27-2008   #52
flyin ryan
flyin ryan's Avatar
thanks for the update/story, Tom. neat. it's a pretty car.
Old 12-29-2008   #53
Where did you find the diaphragm for the pumps?Id like to find a kit put the only place I knew about is out of business.Were the bladders shot or was it just the diaphragm in the pumps?
Old 12-29-2008   #54
Jeffvette
Both the bladders had rotted at the connection points, and the diaphragm in the pump had also ruptured. I repaired the pump and then we discovered the bladders where toast.
Old 12-29-2008   #55
HIZNHRZ
TomC, absolutely beautiful car.
Old 12-29-2008   #56
Polo-1
the good stuff
