10-22-2008 | #51 |
Re: LT5 Assembly Project
LH (Dr.) or RH (Pass.) bank?
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
10-23-2008 | #52 |
D/S bank.
LGAFF 92 ZR1 #234 |
10-23-2008 | #53 |
Nikasil liners....... if it's scratched,chipped it's a gone. You could have it re-nikasiled. Or I have 16 pistons, rings & liners with the rods. 1 set under 10k, 2nd set has 65k on them. Rod bearings are standard SBC.
10-23-2008 | #54 |
o.k., well that's the better side to be on if it has to be, D/S outside. are you able to have it touch honed? maybe 320 or even 400 grit. don't get carried away, just a light rub.
10-23-2008 | #55 | |
I was just looking at the pic of your pan and it reminded me of mine.....after I unbolted the sump I found my dipstick tube seal wedged in the side of the screen......it made me laugh. |
10-25-2008 | #56 |
One of the questions I had was about #s matching engines. I have been told that there were no #s matching before, but this is not correct. I did find that the top part of the block is stamped with the prodution # in this case 5800702, or #702. I also noted that the various pieces have different production dates, the top half of the block was manufactured on 10-3-89, the lower half 10-20-89....the oil pan 8-21-89. So it appears as long as the top half of the block is correct you have a #s matching car.
I have heard from a few forum members that any type of #s matching program may have ceased in 1991. Thought people would find this interesting, by the way, even the valves have date stamps on them. LGAFF 92 ZR1 #234 Last edited by LGAFF; 10-25-2008 at 01:29 PM. |
10-25-2008 | #57 |
Newbie here to LT-5 tech and I am really enjoying this thread.
10-25-2008 | #58 |
Well I bought new head bolts from Jerry and received them today, perfect timing as the wife was out of the house when they arrived...thanks Jerry.
I cleaned some grime off the block, and then examined the pistons I truly think there are 2 that will need to go. But I am going to pull them and look at the sides to see how bad the damage is....maybe sand them alittle and see what happens. I assume the next steps to access the crank bearings and pistons would be as follows: Step 1: Remove the timing chains.... loosen tensioner: and then unbolt the primary chain gear: Any tricks or concerns on the tensioners? The secodary/cam chain tensioners were removed prior to shipping the motor. LGAFF 92 ZR1 #234 |
10-25-2008 | #59 |
I will probably start removing the chains tomorrow:
After the chains, will need to remove the main main bearing caps. From what I can see in order to remove the main bearing caps, the lower half of the block or the girdle will need to be removed. Pic shows were block is in two pieces: The girdle is made of aluminum, and it looks like the steel main caps sit under the girdle in a dovetail fashion: LGAFF 92 ZR1 #234 |
10-25-2008 | #60 |
The girdle is held on by a series of 10mm bolts internally seen here:
and I believe there are 8 external, as seen here: Almost forgot, oil pump might also have to come off.....open for feedback to those that have done this before. Thanks LGAFF 92 ZR1 #234 Last edited by LGAFF; 10-25-2008 at 09:49 PM. |
