12-31-2009 | #51 | |
Re: Anyone with StainlessWorks headers
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
12-31-2009 | #52 | |
There is a vacuum line you need to remove the "T" on and just put a straight coupler on. It is on the driver side fender skirt above the shock tower. |
12-31-2009 | #53 | |
Re: Bracket pictures...
It's no big deal, but like I said it was about a 30 minute job including painting. Here's some different pix. (I would have done what Pete suggested, except on my SW headers, the stock header bolt spacer interfered with the SW header tube. So this bracket attaches at one end under the front #6 port header bolt, and the other end clamps the stock hanger on the dipstick. As you can see, a couple bends, a couple holes, and I had to grind out a divit to allow the dipstick to poke under the edge of the bracket. The dipstick tube is rock steady and keeps the tube away from the header tubes and presents the dip stick nicely. P.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-31-2009 at 05:11 PM. |
12-31-2009 | #54 |
Paul,
Nice, functional fab work
12-31-2009 | #55 |
Paul,
You could make and sell those brackets. I'll buy one!! |
12-31-2009 | #56 | |
12-31-2009 | #57 |
This is funny.....I actually had to remove most of that air induction stuff under the driverside headlight to get to those little radiator screws to remove the radiator not knowing I could just leave that stuff out
01-01-2010 | #58 |
Yes yes!! I remember I used a vac plug like you would on a carbuerator!
01-01-2010 | #59 | |
It will be great to get rid of a lot of that crapola for sure and I also will be running without CATS |
01-01-2010 | #60 | |
P.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
