01-17-2008 | #51 |
Re: Exhaust changes causes problems
ok, just grasping at straws since the car isn't in front of me.
Wonder if they put the injectors in correctly, meaning they used the top indent for the c clip. I would start looking at spark. This is when a scan tool is handy. Just makes it all the easier when you can see fuel trims, knock counts and 02 fluctuations. |
01-17-2008 | #52 | |
Roger Miller 91 ZR-1 #391 |
01-18-2008 | #53 |
Roger,if you have a digital camera take pictures.
Close up of what Jeff mentioned the injectors,unplug a primary and take a close up. I would change the Wires. Pete
01-18-2008 | #54 | |
01-18-2008 | #55 | |
Get your tools together, the Helms manual, and a WARM place to work and you're all set. btw, where in Georgia are you? George 1990 #2957 black/black |
01-18-2008 | #56 |
roger, i think jeff has apicture guide on plenum removal, but not totally sure . I ampositive he could guide you through it . the process is alot easier than you might think . you just have to go slowly and make sure you remove all 4 electrical connectors that are under the plenum 2 from the front and 2-3 from the back 3 if one includes the map sensor . you dont have to seperate the throttle body from the plenum. it comes off in one big piece . but the decision to do it is up to you .is there anyone close that could help this nice guy out ?
01-18-2008 | #57 | |
01-18-2008 | #58 |
Its not really involoved, you can do it. Links here to help you out. Take your time, observe and go slowly.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
01-18-2008 | #59 |
Ok guys, I checked the fuel presure. Here is what I found:
With key on(no engine on) - 46# about 20 minutes later 30# With key on(no engine on and seconary fuse pulled) - 48# 20 minutes 36# WIth the engine on - 44# at idle car off presure at 44# for 20 minutes I don't know what any of this means. Does any of it make sense?
01-18-2008 | #60 |
Roger,
Data indicates the problem is probably not with the fuel pumps. Few questions: 1. Did you ever change the fuel filter? 2. Did you ever experience any of these symptoms, before installing the new exhaust system? 3. Have you pulled the stored codes? 4. Are you getting any warning lights on the display?
