Old 01-26-2008   #51
tpepmeie
Default Re: LT5 ECM Tuning thread
Tyler,
It is a multiplier used to cut the fuel pulsewidth in half when the second set of injectors is active. For example, say you have an base pulsewidth of 10 milliseconds when the engine is running on only the 8 primary injectors. When the ECM commands the secondary throttles open, there is a very slight delay (0.3 sec) then the secondary injectors are energized, and the NEW pulsewidth is now 10ms x 0.51 = 5.1ms. Of course, since it is being delivered with twice the number of injectors, the overall fuel injected is the same as before the port throttles opened.
Increasing this multiplier would have the effect of adding fuel when the secondary injectors are energized. If it were, say, .75, then you would end up with 2 injectors x 10ms x .75 multiplier = 15ms total fuel delivered. This could be used as a band-aid to increase fueling if the injectors are too small or the VE table is not correct. However, I would think the transition would be terrible, and you'd end up with a surge due to the sudden enrichment.
just my $0.02.
Todd
Old 01-26-2008   #52
Tyler Townsley
Originally Posted by tpepmeie
Tyler,
just my $0.02.
Todd
In my book your $0.02 is worth at least $1.00.
You are of course correct. When Jim Smith was trying to tune Ron Ks motor several years ago the car had a lean at this transission and he had the VE tables up to 100 and the car was still lean in transition. We took this to .56 or .57 and solved the problem and were able to back the VE table down some.
The above only applies if you are using secondary throttle plates.
Todd what did you with this when you change the calibration to have both injectors on all the time.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 01-26-2008   #53
tpepmeie
Tyler
I left it alone. So basically had half pulsewidth provided by each injector all the time.
The base fuel calculation has no idea there are two injectors. In fact, the base calculation only knows the constant for 1 injector (.35 sec/gram). The pulsewidth is calculated using this. So, therefore, when you bring the second injectors online with the same calculated base pulsewidth, the scaler has to be used so that you don't deliver twice the required fuel.
Now, about that delay factor....who wants to discuss what effect that has?
Todd
Old 01-26-2008   #54
Todd,
Why don't we discuss Proportional Gain?
Old 01-26-2008   #55
bradslt5
wow todd really know his stuff. this is a good read . when i got a prom from mark haibeck he says he takes some of that out to give a better responce . is that what you mean. i just want to learn all i can . what are your thoughts on tunning is one takes the secondary throttle blades out . do they then run all the time ?
Old 01-27-2008   #56
tpepmeie
Originally Posted by XfireZ51
Todd,
OK. What do you want to know about it? It is pretty simple, and the first of three potential PID parameters to control pulsewidth based on feedback from the O2 sensor. There are primarily two tables at work...one is the base response to O2 error vs. airflow. There is a smaller proportional step at zero airflow (idle).
These steps are then multiplied by a factor, depending on how large the O2 error is. The bigger the error, the larger the multiplier. You end up with an adjustment "count" to modify the base pulsewidth. If the error is positive, fuel is removed and vice versa.
Todd
Old 01-27-2008   #57
Isn't there a constant that defines the max airflow to be considered as IDLE? The 7747 code used a separate Prop Gain Bias constant for idle and the 2D table was pretty coarse.
EBL has 2 constants for Prop Gain at idle based on offset and duration and 4 tables.
So 1 Prop Gain table defining a gain based on Gms/sec which then gets further modified by a second table with factors based on O2 Error, right?
Which one do you usually modify and why?
If I change the gain up or down, what would I feel in the way the motor runs?
Why wouldn't I want to be able to modify this in the bin?
Thanks for this. Any more on the disassembly lesson?
Dominic
Old 01-27-2008   #58
tpepmeie
No. Idle fueling is determined by TPS < 2% and vehicle speed <= 0. That combination sets the airflow term to zero.
There is a scaler term available to modify the Prop Steps, but it is not used (ie, = 1.00)
Todd
Old 01-27-2008   #59
Todd
Thanks Todd. Think I understand what's going on here now.
Old 01-28-2008   #60
Tyler Townsley
Todd
The delay factor is there to let the air velocity catch up to the needed fuel. When you go from 1 to 2 runners in a cyl the increased airflow and pressure change has to be factored into the fueling equation and that is what the factor does.
I hadn't thought about that one in a while. On a removed secondary situation would you lower the delay or remove it alltogeather?
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
