Old 12-04-2010   #51
detch
detch's Avatar
Default Re: What's the Mileage on your ZR-1(s)?
95 #338 34000 miles and no problems=D>
detch is offline   Reply With Quote
Old 12-04-2010   #52
hiperf406
hiperf406's Avatar
My 91 #1748 has 23,000 miles on it. Replaced master & slave cylinder 7 yrs ago, bought new injectors but haven't installed them yet. Runs great. lorne
lorne # 1748
Stock except for a modified Corsa exhaust.
When the flag drops the bull sh1t stops!
hiperf406 is offline   Reply With Quote
Old 12-05-2010   #53
Coupe89
1990 #642 has 83K miles. No major problems.
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 12-05-2010   #54
rhipsher
rhipsher's Avatar
Red on red 90 just turned 90,000 miles. Bought with 65,000. Engine and transmission are like a rock. Never any problems except for normal wear and tear items like bushings and one bent/twisted clutch fork.
Old 12-05-2010   #55
JThomas
JThomas's Avatar
1992 #068 Purchased two years ago with 97,000 miles. Currently the car has 106,700 miles.
I am the third, maybe fourth owner of the car. Unknown previous history, but I have replaced most vaccum lines under the plenum, starter, emergency brake lever, altenator, one valve for secondaries, vacuum pump, primary fuel pump and injectors.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 12-05-2010   #56
4-cam
1991 #31 BLK/ Grey..... 43000 mi. Will get injectors this winter
[I]4-cam[/I]
[I]1991 ZR-1 Blk/Gry #31[/I]
[I]SW Headers/Xpipe- Dynomax Muffs[/I]
[I]Ported top end[/I]
[I]Secondaries Removed[/I]
Tune by Dominic
4-cam is offline   Reply With Quote
Old 12-05-2010   #57
bdw18_123
1990 white/red #2299. Currently has 139,376 miles. Purchased with broken driver's side secondary timing chain and engine partially disassembled.
From what I have discovered so far, I believe this was most likely caused by driving it with an ECM that was causing bad misfiring, though I don't have direct proof of that. The ECM was previously replaced back in 2001 (most likely for the same reason). Carfax shows that the last smog test failed, probably because of the bad ECM.
Damage turned out to be minimal considering the type of failure. Just a couple of bent valves and some scoring on the oil pump, no damage to the block or either of the heads. As of today, it still isn't running, I am in the process of repairing/restoring this ZR-1.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 12-05-2010   #58
91 #987 55k miles. Runs great, no major problems since I purchased it last February.
Old 12-06-2010   #59
Don in VT
Hi
My wife's 90 ZR1 has 34K. New clutch in Sept this year. Runs great. Down for the Vermont winter.
Merry Christmas
Don in VT
Don in VT is offline   Reply With Quote
Old 12-06-2010   #60
Rex Ruby
1994 W/ 53k Bought 2/04 with 30850 mileage
04/09/04 31546 Replace: Vacuum harness under the plenum
Reverse light switch
Serpentine belt
Drain and Fill rear with Mobil 1 and GM Additive
04/15/04 31549 R & R Plenum correct vacuum leak and new gaskets
04/30/05 31715 Install factory correct stock chip
05/29/04 31908 R+R Throttle body and air horn. Clean paint and
install new gaskets
Rebalance front wheels
04/23/05 33645 Install Hurst Shifter
06/25/05 34344 Install new shifter weather boot under console
09/10/05 35750 Replace half shaft U Joints
03/24/07 38695 Install Sylvana Silver Star Headlights
06/26/07 40285 Replace key fob battery DL2450
04/26/08 41815 Replace IAT sensor
07/01/08 43250 Installed Marc Hiabeck Chip
07/10/08 43290 Coolant system service. R & R radiator cleaned
New coolant fill tank and new plug on wire harness
for coolant level sensor (on tank)
New AF w/ distilled water (5 yr. AF)
11/29/08 45682 Used a non-recommended AF in 7/10 service above
Replaced AF w/ GM spec 1825-M
Oil + Filter
03/09/09 46788 Removed Borla resonator and installed X Pipe
08/22/09 48653 R&R HVAC head unit and clean button contacts
03/26/10 50029 R&R Plenium repaired vac leak.
Replaced vac reserve canister that I broke
Replace MAP vac hose
08/22/10 52285 Replaced alternator and serp belt
09/05/10 53030 Replace K&N air filter w/ AC Delco
(Left out oil changes and yearly state inspections)
John Porter
'93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels
* PA Plate: OBSSSN
'06 LeMans Blue C6 Coupe - Corsa exhaust
* PA Plate: OBSSSV
ZR1 Net Registry Founding Member #153
40th Anniversary Registry Member
NCM Family Membership #8116
Corvette Forum NE Events Coordinator
Delco Cruisers Board of Directors
SAVE THE WAVE!
Rex Ruby is offline   Reply With Quote
