Old 05-08-2019   #51
Ccmano
Default Re: Code 41 = new ECM?
Originally Posted by Weeberone View Post
The vacuum hose is still attached to the MAP sensor.
Both ends? An easy check of the MAP sensors is to swap the two MAP sensors in their respective locations and see if you get a change. The other one is under the ECM on a 90’. No change means that’s not the problem.
H
Old 05-29-2019   #52
Weeberone
Well my Haibeck chip showed up about a week ago. The car had been sitting for about 2 weeks, so before I put in the new chip I thought I’d see if it was still throwing codes. Well, of course it starts and runs perfectly. I guess it just needed a really good dry out? I don’t know.
Anyway, with a perfectly good Haibeck chip sitting on the bench 3 feet away what would you do? Of course, put that bad boy in.
So I put in the new chip and start it up. Instantly the CEL comes on. It seems to be running fine though so I take it for a drive.
Obviously there’s an issue as it won’t rev with any power above 5K rpm.
Turns out, in my haste and excitement I didn’t have the new chip seated properly.
Once that was fixed the car ran great!
The best part is the high idle that used to hang about 1200rpm for a few seconds while coasting to a stop drops much faster now and sounds like a normal car.
I’m still having an issue of what I perceive as slightly rough running while accelerating, but I’ll start another thread to ask advice about that.
Thanks for all the help on this problem!
Sent from my iPhone using Tapatalk
Weeberone is offline   Reply With Quote
Old 05-29-2019   #53
Ccmano
That’s good news.... are the injectors original? Plan on changing them if they are, a good chance that’s your roughness.
H
