Old 02-16-2018   #1
S.hafsmo
S.hafsmo's Avatar
Default Re: High searching Idle
Just to mention it, my idle drops 50 rpm (750 to 700) if I plug the bore to the primary blade (IAC obviously still at 0). I'm assuming the air to the remaining 50 RPM are leaking around the secondary blades. These throttle bodies are not the best design.
Primary blade:
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 02-16-2018   #2
jss06c6
Primary blade:
Yep, checked my primary when I had the TB out. It was pretty dirty, so cleaned it up a bit with brake cleaner.. Didn't have quite as much daylight around it as I see in your picture.. Secondary blades had virtually NO light showing around them.. I feel like I'm chasing a rabbit here for which there is no real symptom.. The engine idles well, never stalls when I come to a stop and pulls like crazy all the way to 7500 (no courage to go higher than this!).
Old 02-16-2018   #3
jss06c6
Hot engine..
Idles smoothly at 750 rpm
MAP rock steady at 34 kPa
MAT 44 C, 111 F
Coolant temp 93 C, 199 F
Old 02-16-2018   #4
jss06c6
Cylinder volume reads right on mine.. Marc may have swapped to another BIN..
Old 02-16-2018   #5
I use BRXB for the $AFA Mask. GM changed the Broadcast code for the correct calibration depending on whether it was for the original Mask or if it was for the updated Mask. So $AF would use the AXFK cal, while $AFA would use BRXB for the 91s. As another example, the 92 $D0 bin is AZZC, while the updated $D0A uses BPPA.
Actually, I do think that Mark uses the latter version of the Mask for his cals. No real reason to use the earlier version. As I look at both 91 stock bins, they did play a bit with the IAC and then changed it in the 92. But it shouldn't affect the idle portion.
Old 02-16-2018   #6
jss06c6
Thanks!
Old 02-16-2018   #7
BTW, Hans tells me his stock 90 idled at 750rpm w 6-14 IAC counts.
Old 02-16-2018   #8
Vette73
Couldn't help but read this entire thread on engine idle......One question I have is, how accurate is the tachometers on these cars? I have a 91.....
Mine idles at between 900-1,000 rpm...Motor is fully ported with full exhaust and intake cams...
Even when my car was stock it seemed to favor anywhere from 850-950 usually..
I do notice at times when I pop it into neutral coming to a stop, it may take 5-10 seconds for the idle to " settle in" at around 900-1,000....
Forgive the ignorance , new bee here still learning...👍
Sent from my LG-TP260 using ZR-1 Net Registry mobile app
Vette73 is offline   Reply With Quote
Old 02-16-2018   #9
Not at all. Your questions are welcomed. That's the purpose of threads like this.
To your observation, the IAC controls have "delays" which will hold rpms up a bit using the IAC until you are at a stop. Those delays can be reduced. But IMO, the LT5 has a tendency to want to stall. It reacts quickly to inputs which makes it responsive, and when the motor is modified and events happen quicker, the stock settings represent somewhat of an "overreaction".
So it needs to be "toned down" a bit.
Old 02-16-2018   #10
Ccmano
Most likely your tach is off. They tend to show on the high side with age and they are all old. I would only trust a Tech1 or scanner of some type. I must say using ALDLDriod has been a positive experience.
Looks like your car was modified. I would check the chip and see how it was set up, if at all. 5-10 seconds for the idle to settle down when at full operating temp is not normal. It should linger at higher rpms as you come to a stop but should be back to normal within a second or two.
H
