#51 |
Cliff,
Excellent. Thanks. |
#52 |
WTG Cliff and Phil. GC
#53 |
![]() Join Date: May 2010
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#54 |
#55 |
Awesome ! Excited for this !
#56 |
![]() Join Date: Jul 2016
#57 |
Reports coming in from Dynomite are quite encouraging
Catch up here: https://www.corvetteforum.com/forums...post1596384563
#58 |
Great work guys! Can’t wait to see the final product. I see the utility of using the original housing with the new Delphi regulator. Any possibility of getting an adjustable version?
H ![]() |
#59 |
Would consider it, know of a good one? No noisy Chinese knock-offs.
#60 | |
As far as adjustable version......there are at least 3 Delphi Fuel Pressure Regulators of various pressure ratings that one can change out in a matter of minutes without removing the plenum. Phil only modified the Fuel Pressure Regulator Stock Housing making it easy to insert anyone of several inexpensive Delphi Stock Fuel Pressure Regulators ![]() Initial Fuel Pressure Tests of Improved Fuel Pressure Regulator (IFPR). A. With Engine On at Idle (850 rpm) vacuum line connected to IFPR. Engine idled at 850 rpm with Fuel Pressure Reading 40 psi (Left photo). B. Engine Idled at 850 rpm with Vacuum line to IFPR disconnected Fuel Pressure Reading is 52 psi (Right photo). No Leaks...... ![]() ![]() ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-22-2018 at 10:06 AM. |
