Old 05-17-2016   #51
Default Re: Low RPMs bucking
The sootiness of the plugs is a result of the lean condition the ECM is "seeing" so it's adding more fuel where it really doesn't need it. The O2 sensor must be broadcasting a lean condition which could be a result of a vacuum leak/exhaust leak bringing fresh air past the O2 and therefore it's reporting a "false" lean.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-17-2016   #52
MuRCieLaGo
I know I got a vacuum leak. Tiny one, vacuum pump turns on one time every 3 seconds.
Exhaust leak is also VERY possible... Nobody mentionned it before but it makes sense.
Updated todo list:
3. Tested the resistance on the fuel injectors (car hot).
Primaries
#1: 17.8 ohms
#2: 17.8 ohms
#3: 17.9 ohms
#4: 17.9 ohms
#5: 17.7 ohms
#6: 17.6 ohms
#7: 17.5 ohms
#8: 17.5 ohms
Secondaries
#1: 17.8 ohms
#2: 17.8 ohms
#3: 17.8 ohms
#4: 17.8 ohms
#5: 17.5 ohms
#6: 17.5 ohms
#7: 17.4 ohms
#8: 17.3 ohms
To do:
4. Dynamic test fuel pressure.
5. Check for exhaust leaks.
MuRCieLaGo is offline   Reply With Quote
Old 05-18-2016   #53
MuRCieLaGo
Checked for exhaust leaks tonight, I got a tiny one on each side, about 6 inches after each o2 sensor.
Gonna get it fixed on next tuesday morning, but I don't think it'll fix something here.
Old 05-18-2016   #54
RussMcB
I agree. I've noticed a couple leaks in my exhaust and they haven't affected how it runs (AFAIK).
Old 05-19-2016   #55
If the exhaust leak is behind the O2, what happens is that fresh air gets drawn in during times of high vacuum such as decel and idle. At cruise, vacuum
Is not so high and you won't see an issue.
Old 05-19-2016   #56
MuRCieLaGo
You're a bit right there. Gonna get it fixed as soon as possible anyway, you're giving me some hope now.
Old 05-19-2016   #57
G8nightman
G8nightman's Avatar
How did you test for the leak?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 05-19-2016   #58
Just to illustrate how a small leak can make a difference, I had been data logging and tuning my 84 Xfire. At low MAP and decel, I needed to constantly add fuel.
One day, I was looking behind the car and noticed one of the mufflers hanging a bit low. The joint at the muffler/exhaust pipe was loose. This was enough to skew results. And I had a catalytic converter that was between the muffler and Y-pipe between where the muffler joint was and the O2 sensor. It was pulling fresh air from the back to the front. So there really is no such thing as a "small exhaust leak" when it comes to emissions ECM controlled vehicles running closed loop.
Old 05-19-2016   #59
MuRCieLaGo
Put my hand near the flanges/clamps and I felt some air.
I really need to do some researches regarding that closed loop thingy. I'm not sure I understand how it works.
Thanks a lot for your help.
Old 05-19-2016   #60
G8nightman
G8nightman's Avatar
I will be testing for leaks on my system was thinking of using a smoke machine..
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
