Old 09-08-2016   #51
5ABI VT
Default Re: Nitrous
Very cool ! ANy pics of the install underhood? I have been debating on going this route. If I keep my 93 stroker car I will go with n2o otherwise if I part that car out I will be building a big cube LT5. Maybe just add the n2o on top
Old 09-08-2016   #52
spork2367
Default Re: Nitrous
Originally Posted by mike100 View Post
How do you add enrichment on a dry system? What I'm asking is how do you tell the ECM to add a crapload of pulse width to the injectors and to retard timing a couple of degrees?
With this...
Old 09-08-2016   #53
Default Re: Nitrous
Old 09-08-2016   #54
Default Re: Nitrous
Old 09-17-2016   #55
Default Re: Nitrous
Purge added
Old 09-20-2016   #56
Billy Mild
Default Re: Nitrous
Do you need to run that standalone computer system or can you use the stock ECU?
Old 09-20-2016   #57
Hog
Default Re: Nitrous
Stock ECU works with any ECU, even the stock calibration would be fine with a wet 75hp shot. A window switch on the Port Throttles would be great, nitrous on ONLY when Port Throttles are in full swing.
Old 09-20-2016   #58
Default Re: Nitrous
running stock system going to pull timing through IAT mod or a chip.....will find a better method through a switch after some testing....have to see if I blow the car up first
Old 09-20-2016   #59
Default Re: Nitrous
It has window and WOT switch
Old 09-20-2016   #60
Hib Halverson
Default Re: Nitrous
I'm waiting with baited breath to see how a wet system works on an LT5.
When are you going to go to the chassis dyno?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
