Old 05-29-2015   #51
HAWAIIZR-1's Avatar
Default Re: Jumper to avoid being stranded with a failed Primary Fuel Pump
Craig 1 Each Army wise or One each for both your rides ?
Sorry GC, yes just 1 Each Army wise (can't seem to get the QM out of my system...ha, ha). I don't know if I will keep two ZR-1s as much as I would like to. Please let me know payment details. Thanks again.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-29-2015   #52
902066
Please put me in for one of the 1st 25, and let me know when and how to pay. Thanks Jim.
902066 is offline   Reply With Quote
Old 05-29-2015   #53
HIZNHRZ
Add 1 for me please!
Old 05-29-2015   #54
RyanChappel
Default My Haibeck chip obviates the need for the power key..
Given the concern regarding the potential lean situation by running on only the secondary fuel pump, this fix should be absolutely emergency only?
RyanChappel is offline   Reply With Quote
Old 05-29-2015   #55
Default Re: My Haibeck chip obviates the need for the power key..
Yes this is purely a limp home option as an emergency measure. As such should be stored in your glove box or rear storage compartment for those road trips.
Old 05-29-2015   #56
Ive talked to my local electrical guy about making these. We figure $30 shipped Lower 48. I have asked him about making a run of 20 if we have enough interest. Once we have ten signed up I will tell him to start making them and start ordering the connectors and wire and post up the prototype
1. GOLDCYLON
2. PHILLIPSLT5
3. GEEZER (Canada)
4. ZR1North
5. GSJOE X 2
6. CHRISKINZEL
7. CVETTE98PACECAR X2
8. DYNOMITE X4
9. NELSON007 X2
10. WEGONE
11. SCOTTZ95ZR-1 x2
12. MYSTICZR-1
13. DEMPS
14. ROADSTER
15. HAWAIIZR-1
16. ANDY
17. HIZNHRZ
18. 902066
OK we are at 25. Once the prototype is made I will post of some pics. THEN I will post all the payment instructions.
Old 05-29-2015   #57
zrss
Okay, please put me down for the first 2 from the second batch. Wish I'd seen this a day ago. Thanks.
zrss is offline   Reply With Quote
Old 05-30-2015   #58
tf95ZR1
tf95ZR1's Avatar
GC, I'd like one also.
Thx,
Ted
Old 05-30-2015   #59
Ju
Originally Posted by QB93Z View Post
The Fuel Pump Test Connection in the wire bundle near the ECM cannot power the fuel pumps when the ignition is ON.
The fuel pump test connection is very useful when 12 Vdc is applied with an ammeter. A running fuel pump will draw about (I don't remember the exact number) 4 amps. If the ammeter reading is > 8 amps, then two pumps are running in test mode.
I was told by someone in Marc Haibecks shop that the secondary FP pigtail can be used in place of a failed primary FP. For the past year I've had piece of mind knowing the jumper I've had in the car will get me out of a jam. Anybody that wants to make one of these can get all of the GM,Delphi,Packard hardware from Terminal Supply.
Old 05-30-2015   #60
edram454
edram454's Avatar
Ok any others out there ?
count me in too. edram454 #3028. I have been gone for a couple of days and I just read this. sounds like a great idea.
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
