12-10-2014 | #51 |
Re: Brighter Aftermarket Headlamps
Less than $600 for the LED and no additional parts/fabrication to install does have a certain appeal. Will the weight be more than a glass headlamp? Less current draw (and therefore heat) is also a big plus on the charging system.
12-10-2014 | #52 |
I did not weigh the glass headlights I took out, but let me research the weight thing and post back here later.
12-10-2014 | #53 |
I didn't remember a "Peter Z" posting here.
Maybe I missed a post?
12-10-2014 | #54 |
I haven't used my headlights in about 15 years Im not a fan of how they look popped up but at night.. Im leaning towards having exceptional visibility over worrying about how the car looks. Ive had plans to modify headlight housings to create a lower profile look but I had a few close deals on headlamps and couldn't agree on a price. Sort of glad I hadn't bought any yet as my plate has been beyond full this year.
Anyhow I have the HID fog lamps on the z and my 93. They definitely are brighter than oem but they are horrible for visibility where needed. the light scatters everywhere. Im modifying the bulbs to direct more light forward and down instead of all over the place with shields. They really aren't a good replacement for headlights. After having my e46 M3 with bi-xenons... I am leaning towards using headlights again. I must admit I actually like the look of these headlights. Still big and square but the bar across the middle looks pretty neat ! I already have a few ideas how I would modify them. I read the review on cf, thanks for that. I think I may have these for the 15 season. Last edited by 5ABI VT; 12-10-2014 at 06:49 PM. |
12-12-2014 | #55 |
Just found out that Amazon.com has a $100 off coupon available for Nighthawk LED 5x7s. Price ends up about 390 for a pair.
12-12-2014 | #56 |
How do these compare in intensity etc to quality hid/xenons? I see a lot of info on durability etc but I'm wondering how they compare in light output vs a oem xenon setup like on my old e46 m3. While the bulbs burn out eventually and lose light output the xenons are relatively cheap to replace.
12-15-2014 | #57 | |
Also, on the earlier weight question: I have some information and still looking for more. Glass reflectors with H4 bulbs (i.e.: Hella, Cibie and etc) weigh in at about 1-lb. 6-oz. to 1-lb. 12-oz The stock sealed beams in the earlier cars which were glass will be about the same. The stock sealed beams in the later cars which were plastic will be quite a bit less. A Nighthawk LED weighs 2 lbs 10-oz and the extra weight is likely from the aluminum housing.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 12-27-2014 at 03:35 PM. Reason: added content. |
12-16-2014 | #58 | |
It doesn't need to be complicated; as long as some basic fundamentals of (light) propagation are understood (or explained for the audience reader) and some standard method of calibration of light intensity measurement is assured, or failing that, some consistency of measuring devices be used to evaluate the various (lights) under test. And, too, a standard coverage area (grid?) be established to better evaluate the various patterns these light may/will deliver. I don't think it would be all that difficult to do some objective testing, as long as all the various light systems were available in one place to test. No? I see that as being the more difficult piece, actually. Establishing a (target) and doing the measuring I feel wouldn't be so difficult. Getting all the lights for testing in one place at one time is what I wonder about. (Sounds like a simple enough project, or one that perhaps would be of interest to a physics prof to turn over to his students as a project!) Anywayz, that might be a good way to separate the "lumens from the lemons", so to speak. What do you think? PM me if you think you might be interested in genning up a clinical approach that might work, and we can discuss how to go about it.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-16-2014 at 07:06 PM. |
12-17-2014 | #59 |
Paul-
You raise some great questions but, unfortunately, to answer them properly would be quite expensive. The costly parts are 1) acquiring a device which measures the amount of light intensity projected out, ahead of the car and 2) acquiring enough lights to test and the labor involved in swapping all the lights. The "Lummens from Lemons" name. That's good!
12-18-2014 | #60 |
A light meter; $40.00 to $2000.00!
