#51 | |
#52 |
If I did have a vacuum leak, wouldn't the idle be fluctuate all the time? I just don't see who it could be leaking. I have used a vacuum pump to check all the connections and nothing seems to be leaking.
#53 |
Here is a little video of what I am dealing with when the car is fully warmed up.
http://youtu.be/TjD4C59Q9gA |
#54 |
I had a suggestion from Marc Haibeck that it could be the PCV grommet for the valves. I checked that today and it was ziptied to the tops of the PCV valves. Is there anyway to pressure test that system?
Another thing I noticed today. If the AC is on the idle is pretty much perfect. It doesn't fluctuate at all. Is that normal? Could this all be IAC related? |
#55 |
That's because the AC put a load on the motor and moved the idle to a different/richer part of the VE table. Suggests to me that your oscillating idle is due to a lean surge. The VE table at idle needs to be flattened out, probably along w the SA table altho I would look at Closed Throttle Idle SA setting.
#56 | |
#57 |
Any idea on what to look at?
