04-24-2014 | #51 |
Re: Headers Installation...
Lean burn = HOT burn; higher NOx's, lower HC's
Rich burn = cooler burn; lower NOx's, higher HC's EGR add exhaust to intake burn mix to lower burn temps, reduce NOx's.
04-24-2014 | #52 |
I agree. But plugs are white. Kind of contradicting the emission readings. New cooler plugs tonight and rescan.
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic |
04-24-2014 | #53 |
Cold plugs might elevate HC's. I once put in a plug 3 ranges colder on a tpi engine that was only 3 years old at the time- and it would not pass the smog check on our shop analyzer (I used to do this back in the 90's before they went to 5-gas). We used to use the gas analyzer more for tuning than smogs some days, but there is a sweet spot so I would say to never go more than +/- 1 heat range or you could be chasing your tail for awhil;e trying to get the car to run clean.
04-24-2014 | #54 | |
also, high HC's, but good CO could be from a lean misfire/vacuum leak or weak ignition causing incomplete combustion. the o2 levels help tell the story on lean vs rich conditions. even a restricted injector will contibute to lean, but my money is on vacuum leaks/ignition issue. |
04-24-2014 | #55 |
Could be condensation, but it's been cold and DRY all Winter - I know that cause I been electrocuted every time I got out of my car this Winter.
D side has been a cakewalk so far - kinda' bothers me, although pipe is still hangin' by the centering stud ( break time ), and need solvent for block pan cleanup. Still need to know if there was a spec for flange bolt skipping. Each side had same 6, of 16 bolts. Anyone?
04-24-2014 | #56 | |
04-25-2014 | #57 |
They all came with several missing. I didnt count as I knew that they were short from the factory from previous posts so it didnt surprise me. Id guess 4 to 6 were not there on each side. I think I'm missing at least two per side on the SW headers I just installed as the bend is to tight to get them all in.
04-26-2014 | #58 |
I have two of the same washer left over! They fell out when I removed the fender well. Aluminum and about 1/8 in. Thick. Looks like a shim but I dont know were mine came from
04-26-2014 | #59 |
Both of those F/W washers are present AAF there Darby, masking taped into place...
04-26-2014 | #60 |
Where do they go? Mine are still on the work bench.
