#51 |
![]() Join Date: Jan 2004
You should see the Rooster tail it creates when I drive in the rain. I look like a drag boat. lol
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
#52 |
![]() Join Date: Jul 2007
Hey Tony,
Any pictures of where you have the hood scoop attached to the hood itself?
#53 | |
Send me a personal PM if you want anything else.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 Last edited by Tony Davila; 11-28-2013 at 10:00 PM. |
#54 |
Thanks!!
#55 | |
![]() ![]() ![]() Hope that helps.
#56 |
Cool thanks, how does the greenwood piece attach?
#57 |
4 bolts and your choice of urethane adhesive. I did modify the scoops up front which was the majority of the work.
http://www.vetteweb.com/tech/vemp_06.../photo_21.html
#58 | |
![]() Join Date: Jul 2005
The only problem would be if the top of the LT5 is offset from the body centerline. I can't tell from your shot Tony, the angle might be slightly off. Is it right down the middle? |
#59 |
Engine is slightly off center towards the passenger side.
#60 |
![]() ![]() Join Date: Feb 2010
Tony, it's always a pleasure to see your tastefully modded "Z"!!
Brett
